Manuel Grayhawk or electric Draper ?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 03-01-2002, 12:05 PM - Thread Starter
Kriszty's Avatar
Which screen i should choose ?
I pay the same price here in Holland, for the manuel Stewart grayhawk or the electric draper Silloutte V High Def Grey screen.
What is the best choice to make? Both screens is 82 inch of format, i'm using a sim2 ht200dm projector. The grayhawk is 0.95 gain and the Draper is 0.8 gain.
what should i do,
please any suggestions !!!!!!!!!!!!!!!!!!!!!!!
Kriszty is offline
post #2 of 7 Old 03-01-2002, 03:17 PM
Daniel Hutnicki's Avatar
Without taking the screen material in consideration, when I spoke to Don Stewart, he told me not to get a pull down as they screw with the screen.
On the other hand, I have a Dalite manual pull down and have not had any problems with it at all. No waves or anything.
Daniel Hutnicki is offline
post #3 of 7 Old 03-02-2002, 06:24 AM - Thread Starter
Kriszty's Avatar
thanks for the reply ,
i prefer a eletric screen but i think the stewart manual pulldown is not a bad choice, it is also tensioned so i think the screen maintain flat ( i hope so ) the other possibility is the Draper screen but this has a lower gain 0.8 ,but it is electric ..
difficult choice !!!
thanks anyway
greetings, Kriszty
Kriszty is offline
post #4 of 7 Old 03-02-2002, 09:03 PM
Carl Brinkman's Avatar
Kriszty,
Have you considered the Firehawk rather than the Grayhawl ? I saw the Sim@ 200 at CES in January and it was stunning with the Firehawk.
Carl Brinkman is offline
post #5 of 7 Old 03-03-2002, 01:14 AM - Thread Starter
Kriszty's Avatar
yes i considered the new firehawk against the grayhawk, but it think the firehawk will be to bright for my screensize ( only 82 inch ). At this moment i'm using a mat white screen 1.1 gain and even i think the picture is to bright. so i think a negative gain will do good for me. i'm only wondering about the manual pulldown quality from stewart ?
kriszty
Kriszty is offline
post #6 of 7 Old 03-04-2002, 07:39 AM
bhadsell's Avatar
Overall, I think the quality of both products is high, and would be quite a nice addition to your theatre. I would ask, however, why a choice between manual or motorized? Is it strictly cost, or are there other factors as well?
Bob Hadsell
Home Theatre Sales Manager
DRAPER, Inc.
bhadsell is offline
post #7 of 7 Old 03-04-2002, 07:56 AM - Thread Starter
Kriszty's Avatar
Yes the choice i have to made it's the extra costs !! i pay here in holland for both screens around 2900 Euro's and for the electric Stewart i pay around 4500 euro. So i have to made a choice between these two screens, from the Stewart i know this is a good screen, from the Drapers High Def Grey i know nothing about, it seems to have the same gain, but i don't know about any users who has used this screen and how it performs against the stewart . i thought the draper has a gain of 0.9 and the setwart a gain of 0.95 so that is not a issue.
Kriszty is offline
Closed Thread Screens
