G70 and Screen Size - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-06-2002, 06:33 AM - Thread Starter
scottatl's Avatar
I just purchased a G70 – now the screen. I am more concerned for the brightness then the size. I like a little light on the side so I can at least see my wife (she is hotter then anything the bulbs will burn). Will a smaller screen, say 72" wide give me a brighter picture.
I think I will by a 4:3 and mask to 16:9 that way all I have to do is worry about the width.
scottatl is offline
post #2 of 2 Old 03-06-2002, 07:55 AM
snowmoon's Avatar
Yes a smaller screen will be brighter.
To figure out HOW bright...
ANSI lumens * Screen Gain = lumens on screen
Screenlumens / Screen sqft = Foot lamberts ( sp? )
9 is minimum for movie theaters
12 is bright movie theater
30-40 is TV bright
Personally I have a 16:9 72" wide with a 1252 so...
200 ansi lumens * 1.2 gain screen = 240
240 / 20.25sqft = ~12 ftlm
I can have a lights on as long as they are draped properly and not reflecting on the screen. It degrades black levels, but it helps for playing games.
Eric
"Any technology distinguishable from magic is insufficiently advanced" - corollary to Clark's Third Law
snowmoon is offline
Closed Thread Screens
