Screen for Panny 711xu - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-06-2002, 11:37 AM - Thread Starter
Michael_J's Avatar
Looking for a good screen for my upcoming panny 711xu.
My HT is 11.5 x 29.5 x 7.1 (W x L x H) completely light controllable and seating will be at roughly 14ft and 19ft.
I am limited to a 60x80 due to the low ceiling. I will be masking to 16:9 as described at projector central.
Viewing will be split up pretty evenly between DVD, TV and video games (D@#$ teenagers).
Any and all suggestions will be much appreciated, want to do it right the first time...
Mike J.
Better sound in my car than in my house... for now!
Michael_J is offline
post #2 of 2 Old 03-06-2002, 04:35 PM
dm
dm's Avatar
http://www.avsforum.com/avs-vb/showt...hreadid=119320
Gidden flat Universal Grey painted DIY screen worked well for me. I painted some 1/8 inch thick hardboard (similar to peg board material but with out the holes) cut to 46" x 81" with primer and the Gidden paint. Then screwed it to the wall with 1x3 black painted wood frame to trim it down to 45x80 16:9. Cost about $45 total in materials.
I use a Da-lite Model B 57x60 manual pull down for 4:3 aspect ratio stuff (cost about $100 shipped) that pulls down in front of the wall screen.
My projector has a zoom lens so I zoom in for the smaller width 4:;3 aspect ratio screen. I prefered the smaller screen for 4:3 stuff since most of that is NTSC line doubled (with dscaler) video that has lower quality.
dm is offline
Closed Thread Screens
