Microlite Optical Screen - Page 15 - AVS Forum | Home Theater Discussions And Reviews
 19Likes
post #421 of 421 Unread Today, 09:32 PM
Ximori's Avatar
Quoted: 41 Post(s)
Originally Posted by Craig Peer View Post
That's my initial impression based on the 8" x 10" sample I have. It is difficult to judge without a full size screen. But this material is promising for people that need a grey screen.
Indeed. But maybe it's for people that need a white screen as well - since it resembles very similar properties of a white screen, however, with an advantage of not washing out certain mixed scenes due to its higher ansi CR retention properties.
I'm actually referring more to the F3 above, that is, if the ansi measure holds true or similar with the F2. The F2 is quite promising too, being a dark grey material, similar to that of the DNP, giving you perceived blacks while simultaneously providing a 1.8 gain. You'd never imagine it was a gray material at all. I just wish there's an improvement in color and smoothness; otherwise, it would've been my top choice.
Ximori is online now
Reply Screens
