Microlite Optical Screen - Page 16 - AVS Forum | Home Theater Discussions And Reviews
 132Likes
post #451 of 1144 Old 09-08-2015, 09:23 PM
millerwill's Avatar
Quoted: 535 Post(s)
Liked: 316
Interesting that the higher gain version, the F3, seems to be more artifact-free than the lower gain (gray) version, the F2, at least according to reports.
millerwill is online now
post #452 of 1144 Old 09-08-2015, 09:25 PM
biliam1982's Avatar
Quoted: 492 Post(s)
Liked: 249
Is anyone able to get samples yet? I'm seriously considering getting the 144" 16:9 but am not sure if I should go with the F2 or F3. I have a fair amount of ambient light during the day but most can be controlled with blinds and curtains.
I'm currently just projecting (
I think it's about 138" 16:9 at the moment) on a neutral earth tone beige wall which surprisingly looks very good. At normal seating distance of 12', you can't see anything, but up close, the finishing texture on wall is very visible.
I'm using a Sharp XV-Z30000 and have a JVC 6710 coming in probably sometime next week.
I do have a 116" wide 2.35 Da-Lite High Contrast High Power sitting boxed up in the garage. I might be able to bring that in for a shoot-out and also throw up a white linen sheet for good measure.
As for the setup... eye level is just over 40" from the ground. With the AVR stand and Center Channel Speaker, the bottom of the screen will be about 30" or so off the ground. So about 10" of the screen from bottom will be at eye level. The projector is about 5'6" off the ground. Some of these measurements could change depending on what screen I get and the height of an upgraded center channel speaker.
As you can see, the room is pretty wide so the outer seats are not in a "sweet spot." I'd say they're close to 45 degrees off center and more towards the edge of the screen. Though they are only occupied half the time. Most of the time the main couch is used. But, with such wide viewing angles, this screen sounds like it would fir the bill.
Facing the wall where the screen will go, off to the left is the kitchen where there is a fairly large window but it has blinds and curtains. Behind the screen you can see the large sliding glass doors that lead to the back patio which also has blinds and curtains. But, off to the right of that, that you can't see, is a regular door that leads to the back patio and doesn't have and curtains or coverings. And facing the wall where the screen will go, to the right in that hallway is the front door with windows that doesn't have any coverings either.
During the day, we can close all the blinds and curtains and controls most of the light. There is some light that leaks through directly onto the screen wall and from the front door area but it doesn't hit the screen directly from there.
There are only two main lights in the room from above light fixtures which you can kinda see in the pictures. They are not recessed. One is directly over the seating area and another directly behind the seating area in the open space. Usually they are not on. Sometimes we leave the kitchen lights on and those are four recessed 60 watt equivalent CFL bulbs.
Hope this helps explain the room and environment. Any thoughts?
Name:	living room rear facing.jpg
ID:	930954   Click image for larger version
Name:	living room front facing.jpg
biliam1982 is offline
post #453 of 1144 Old 09-08-2015, 09:43 PM
Ximori's Avatar
Quoted: 252 Post(s)
Liked: 151
biliam1982, just give him a call tomorrow and show him your setup and photos. The projector's location isn't in the ideal position as it needs to be higher. He might suggest the F2 coz it rejects light better than the F3 one.
Ximori is offline
post #454 of 1144 Old 09-08-2015, 09:55 PM
biliam1982's Avatar
Quoted: 492 Post(s)
Liked: 249
Thanks. I was talking with Michael briefly over email and did send him this info with the pics, but never heard back from him.
post #455 of 1144 Old 09-08-2015, 10:28 PM
ch1sox's Avatar
Quoted: 323 Post(s)
Liked: 114
Hmm maybe try again. He's always responded to me within 1 day. You can also call 1-877-668-8856.
ch1sox is offline
post #456 of 1144 Old 09-10-2015, 08:10 AM
Home Theater Lover
Craig Peer's Avatar
Quoted: 4145 Post(s)
Liked: 4229
I'm currently just projecting (I think it's about 138" 16:9 at the moment) on a neutral earth tone beige wall which surprisingly looks very good. At normal seating distance of 12', you can't see anything, but up close, the finishing texture on wall is very visible.
Move that AVR rack so you can mount the screen lower. I wouldn't want to be distracted by equipment LED's myself. Put the center channel on a low stand ( Sanus makes a good one ). My screens are more like 17" off the floor ( 123" diagonal 16:9 ). Much easier to watch. Get a low center channel stand. Those are my thoughts.
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is offline
post #457 of 1144 Old 09-10-2015, 01:35 PM
Mike Garrett's Avatar
Quoted: 7096 Post(s)
Liked: 4797
F2 is what I recommended to Bill.
mjgarrett100@gmail.com
Mike Garrett is online now
post #458 of 1144 Old 09-10-2015, 01:36 PM
Liked: 4797
Michael has samples to send out to several people. Your name is on the list.
post #459 of 1144 Old 09-10-2015, 02:06 PM
Quoted: 13 Post(s)
Liked: 2
Mike asked me to put up a purchase post here. I just ordered the Microlite F2.0 screen, 100", 16x9.
Attaching pic so you can see my setup. Light controlled basement, however want to use the screen both completely dark and with lights for sports. 130" throw and 145" seating at couch. Projector is 5-6" above the screen height. I'm pushing the throw and size, but not maxed out. Interested to see how this will turn out.
Epson 5030UB with screen goo current. Keeping everything but the screen the same. I'll let you know my impressions after install and tweaks to picture.
This sight has been very helpful over the years - pretty sure this is my first post....
Rathiem is offline
post #460 of 1144 Old 09-10-2015, 03:08 PM
Home Theater Lover
Craig Peer's Avatar
Liked: 4229
Looking forward to your feedback !
post #461 of 1144 Old 09-10-2015, 03:41 PM
ch1sox's Avatar
Quoted: 323 Post(s)
Liked: 114
Nice! Do you know when you'll be receiving it? I think a couple other members are getting theirs this month.
ch1sox is offline
post #462 of 1144 Old 09-10-2015, 08:04 PM
blee0120's Avatar
Quoted: 654 Post(s)
Liked: 333
My F 3.0 will be here on the 15th.
mbw23air likes this.
blee0120 is online now
post #463 of 1144 Old 09-10-2015, 08:23 PM
millerwill's Avatar
Quoted: 535 Post(s)
Liked: 316
Will certainly be interested in your evaluation.
post #464 of 1144 Old 09-10-2015, 08:26 PM
thrang's Avatar
Quoted: 2004 Post(s)
Liked: 1667
Apparently a delay until November for larger than 120" screen sizes...
thrang is offline
post #465 of 1144 Old 09-11-2015, 05:06 AM
Quoted: 13 Post(s)
Liked: 2
October sometime. Don't have the tracking notice yet. Pretty sure it's shipping from China rather than domestic.
Rathiem is offline
post #466 of 1144 Old 09-11-2015, 08:41 AM
thezaks's Avatar
Quoted: 525 Post(s)
Liked: 112
And you know that because......perhaps you are getting one??
Dave
thezaks is offline
post #467 of 1144 Old 09-11-2015, 08:44 AM
thrang's Avatar
Liked: 1667
Dave
Oh, I'm just an inquisitive soul....
Mike Garrett likes this.
thrang is offline
post #468 of 1144 Old 09-11-2015, 08:47 AM
thezaks's Avatar
Quoted: 525 Post(s)
Liked: 112
Me too...at this point. Hopefully, I will be on the purchasing side of it one day - most likely, when the motorized version arrives.
Dave
thezaks is offline
post #469 of 1144 Old 09-11-2015, 11:18 AM
liloatavs's Avatar
Quoted: 85 Post(s)
Liked: 38
Thanks for posting the picture. I am also looking forward to your review. I am planning to buy a projector and a screen for a similar setup (fully light controlled media room with white ceiling and beige walls to be used for movies and sports). I have never had a projector before. Even though I tried to learn as much as I could about the issues and compromises involved in projector setup it is almost impossible to make a decision without having actually seen the picture resulting from the set of trade-offs one chooses.
liloatavs is offline
post #470 of 1144 Old 09-11-2015, 02:50 PM
Quoted: 13 Post(s)
Liked: 2
I really am hoping this is the magic combination. I started with a Panny 100u and a fixed elite white screen. Can't remember which. Then to current projector and DYI white paint and then the screen goo in grey. It's definitely gotten better with each iteration. So hard to tell with projectors and screens cause ready ability to preview them is nothing like TVs. You can't go wrong in the dark. It's the lights that the guess work starts.
Rathiem is offline
post #471 of 1144 Old 09-11-2015, 03:58 PM
thezaks's Avatar
Quoted: 525 Post(s)
Liked: 112
Looking forward to your thoughts, and hopefully, some pics as well!
Dave
thezaks is offline
post #472 of 1144 Old 09-11-2015, 05:58 PM
Wondercarrot's Avatar
Quoted: 23 Post(s)
Gents, I'm in.
144" F3 16:9
Ordered from the always helpful mike@avscience.com
Replacing a 133" HP 2.4
Very excited.
Wondercarrot is offline
post #473 of 1144 Old 09-11-2015, 07:06 PM
ch1sox's Avatar
Quoted: 323 Post(s)
Liked: 114
Originally Posted by Wondercarrot View Post
Gents, I'm in.
144" F3 16:9
Very excited.
Nice, looks like we'll finally start seeing a bunch of user reviews.
ch1sox is offline
post #474 of 1144 Old 09-11-2015, 07:15 PM
millerwill's Avatar
Quoted: 535 Post(s)
Liked: 316
Gents, I'm in.
144" F3 16:9
Very excited.
Wow, this is very close to my setup, a 144'W x 72"H HP2.4 screen; I zoom to 144"W for 2.35 pic (which are then ~ 60"H), and to 136x72 for 17x9 HDTV (using all the Sony1100's pixels). What is your projector? I will be very interested to hear if you think the MicroLite gives a higher quality pic than the HP2.4.
post #475 of 1144 Old 09-12-2015, 04:36 AM
Quoted: 23 Post(s)
I've got a Sony vw95es
PJ is 18' from the screen in light controlled cave.
While I'm certainly no expert like many here, I'll be more than happy to give you my thoughts between the 2 screens when it comes in.
Can't wait!
post #476 of 1144 Old 09-12-2015, 05:12 PM
we7313's Avatar
For those who have successfully ordered, can you share some idea of what these screens are going for?
we7313 is offline
post #477 of 1144 Old 09-12-2015, 08:02 PM
ch1sox's Avatar
Quoted: 323 Post(s)
Liked: 114
Contact Mike Garrett.
ch1sox is offline
post #478 of 1144 Old 09-14-2015, 04:54 PM
biliam1982's Avatar
Quoted: 492 Post(s)
Liked: 249
I just measured it and I might be able to move the center console to the corner by the recliner. May be a little tricky with some of the remotes that need line of sight though
I thought you told me F3? Well when I get the samples I'll hopefully be able to tell what would work best.
post #479 of 1144 Old 09-15-2015, 02:37 PM
we7313's Avatar
Mike has not replied. Is there another contact?
we7313 is offline
post #480 of 1144 Old 09-15-2015, 03:03 PM
ch1sox's Avatar
Quoted: 323 Post(s)
Liked: 114
fyi, I just sent you his contact info.
ch1sox is offline
Reply Screens
