Elite Sable Frame Series Screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-20-2010, 12:22 PM - Thread Starter
richandy's Avatar
Anyone knows if this is better than the EZ-Frame series? I am planning to either, but would like some opinion on both.
richandy is offline
post #2 of 3 Old 09-20-2010, 12:58 PM
jayn_j's Avatar
Quoted: 62 Post(s)
Liked: 41
Better is a relative term. It is less expensive, but has fewer options. I wanted a white 120" screen, so the Sable saved me about $100. You can't get the Sableframe in the Gray color, or acoustically transparent.
There is a pretty complete discussion here: http://www.avsforum.com/avs-vb/showthread.php?t=1214441
jayn_j is offline
post #3 of 3 Old 09-20-2010, 04:15 PM - Thread Starter
richandy's Avatar
Thanks for the link, and your reply. I will get the sable frame as the difference, it seems is the frame itself.
richandy is offline
Reply Screens
