Your screen size/throw/seating distance - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #61 of 74 Old 07-18-2015, 05:40 AM
ERuiz's Avatar
Quoted: 566 Post(s)
Liked: 179
1) What projector are you using? Sony HW40ES
2) What is your throw distance? 15'-3"
3) What is your seating distance? 11'
4) What screen: size brand, aspect ratio, and gain? 138" | Elite Sable Frame 2 | 2.35:1 | 1.1
5) If you were buying a new screen would you go bigger, smaller, or same size? Same size
FOR SALE: Sony HW40ES / BIC Acoustech PL-200 sub
LG 65C7P / Denon AVR-X4300H / Klipsch RP-280F / Klipsch RP-450C / Klipsch RP-150M (x4) / Klipsch RP-140SA (Atmos) / HSU VTF-3 MK5 DualDrive / PS4 Pro / Oppo 203 / Logitech Harmony Elite
ERuiz is offline
post #62 of 74 Old 07-18-2015, 07:03 PM
Swolephile's Avatar
Quoted: 896 Post(s)
Liked: 356
What projector are you using? Epson HC-3500
2) What is your throw distance? 13 feet
3) What is your seating distance? 13 feet
4) What screen: size, brand, aspect ratio, and gain? 120" Silver Ticket ALR 16:9, 1.5 gain screen
5) If you were buying a new screen would you go bigger, smaller, or same size? Would definitely go smaller. Looking to go back down to either a 100" or 110".
Swolephile is offline
post #63 of 74 Old 09-17-2015, 09:45 AM
frey1esm's Avatar
Quoted: 25 Post(s)
I noticed that with ERuiz and others, their seating distance is closer than what's recommended by Projector Central Projection Calculator, yet people are happy.
For example, ERuiz is at 11' and happy. But the calculator (sorry I can't post links yet) says the seating distance should be between 14'10" and 23'3".
Does bigger just seem better cuz it's bigger? Or are there other factors involved besides screen type, size, and projector model/throw??
frey1esm is offline
post #64 of 74 Old 09-17-2015, 11:06 AM
Home Theater Lover
Craig Peer's Avatar
Quoted: 4117 Post(s)
Liked: 4208
That isn't showing a seating distance. That is the throw distance - the range where you can install the projector.
http://www.projectorcentral.com/Sony...ulator-pro.htm
As far as screen size as it relates to seating distance, read this - http://www.projectorcentral.com/buil...een_size_2.htm
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is online now
post #65 of 74 Old 09-17-2015, 11:21 AM
frey1esm's Avatar
Quoted: 25 Post(s)
It shows both - correlated.
See attached.
Recommended Seating: 14' 10" - 23' 3"
At Throw Distance: 15' 3"
Name:	Screen Shot 2015-09-17 at 2.11.56 PM.png
frey1esm is offline
post #66 of 74 Old 09-17-2015, 11:56 AM
Home Theater Lover
Craig Peer's Avatar
Liked: 4208
See attached.
You are right - I stand ( or sit ) corrected. Seating distance is a personal thing - some like to sit very close. Some don't. I'm sitting much closer than PC's " recommended distance " myself. I'm 11' 3" from a 128" diagonal 2.35:1 screen, and 10' 9" from a 122" diagonal 16:9 screen. I don't feel it's too close - and some here would sit even closer. It will depend on the type of screen material you have, the projector and your source material too. And if your wife likes to sit that close !
post #67 of 74 Old 09-18-2015, 10:11 AM
Home Theater Lover
Craig Peer's Avatar
Liked: 4208
I don't use anything on that calculator at PC other than the throw distance / screen size information. The brightness shown is based on manufacturer's specifications - which are notoriously un-reliable. Just FYI.
post #68 of 74 Old 11-10-2015, 04:21 AM
thetman's Avatar
Quoted: 318 Post(s)
Liked: 105
when everyone states throw distance- is that the actual footage from screen where you have the projector installed? It would be informative and helpful to others to know how far exactly people are mounting their projectors.
thetman is offline
post #69 of 74 Old 11-10-2015, 07:38 AM
Dave in Green's Avatar
Quoted: 2020 Post(s)
Liked: 1306
Throw distance is defined as the distance from the lens to the screen. Technically the measurement should not be made from the projector's mounting point or any part of the projector's case but only from the front of the lens.
Dave in Green is online now
post #70 of 74 Old 11-10-2015, 11:18 AM
Home Theater Lover
Craig Peer's Avatar
Liked: 4208
My projectors are mounted approximately 14' lens to screen.
post #71 of 74 Old 11-10-2015, 01:05 PM
thetman's Avatar
Quoted: 318 Post(s)
Liked: 105
thats good to know thanks. I may just keep the opening for the mount where it it is then on my build. I was thinking of moving it back a few feet since I believed it was going to be too close ( JVCRS4910 with 120 2.35 carada screen) I thought maybe someday if I go bigger then I would definitely have to move it back according to JVC and projector central's scales. But you are at that distance and are using a bigger screen. thanks for the info, helpful
thetman is offline
post #72 of 74 Old 11-10-2015, 01:28 PM
Home Theater Lover
Craig Peer's Avatar
Liked: 4208
In my case due to my room, and the fact I wanted the projector mounted in a closet where I wouldn't hear them, 14' was about as far as I could mount them anyway. It all worked out close to ideal. My wife wouldn't be happy with a larger screen. You can get an idea of my theater by checking out the photos in my signature link.
post #73 of 74 Old 11-13-2015, 01:44 PM
SilentJ20's Avatar
Quoted: 30 Post(s)
Liked: 36
1) Projector: Epson 5020UB
2) Throw Distance: 11'
3) Seating Distance: First Row = 9' Second Row = 15'
A touch close for the first row, but also not too small for the back.
4) Screen: Ultra 100" 16:9 1.1 gain (too bright for this projector, even on eco mode)
5) Planning to do a 100" white-white spandex AT screen (0.9 gain)
SilentJ20 is offline
post #74 of 74 Old 11-14-2015, 06:59 AM
bud16415's Avatar
Quoted: 1068 Post(s)
Liked: 409
1. Projector used, I have two projectors that I interchange 5 minute exchange time 4:3 Sharp XR10X and a 16:9 Viewsonic PJD5555W.
2. Throw distance, My throw is variable as my projector drop is mounted to a front to back moving slider with projector facing backwards bouncing the image from a mirror very much like how the new ultra short throws work only with a longer throw projector. My room is 10’ deep but my throw length is 11’ to 14’. Zoom is kept about mid point.
3. Seating distance, My seating distance eyes to screen is 8.5’.
4. Screen size etc, My screen is the entire wall 9’ high x 11’ wide but normal 16:9 movies are 100” to 110”. I project any and all AR from the two projectors with any image placements on the wall I like. The wall was finished smooth and painted with a simple mixture of latex paint mixed with clear poly. It is a wide dispersion screen and neutral gray in color with a gain someplace between .5 and .6, I haven’t measured it. With that screen I find masking almost unnecessary but have a method of masking at the mirror I use for scope content that works to kill the last little shadows if I desire.
5. If I changed anything and I doubt I will, I would extend my slider/throw length and go with a larger mirror to expand my scope movies just a bit. With the Chief mount and the slider and needing to refocus manually The hardest part of changing a image size is getting the one step stepstool out of the closet. Takes a couple minutes at most. I was a lot like the OP never wanting to pull the trigger on a screen so I figured out a way I didn’t have to.
Bud
bud16415 is offline
Reply Screens
