That is the question, recently I became the proud new owner of an Epson 8350 and started researching screens. I have shown it on my wall for a week and a half and have decided on a 120 inch 16*9 screen for my room. This now leads to the difficult decision of a screen and a tight budget hence no high power.
So now I humbly ask for advice of the those more experienced than I.
Projector: Epson 8350
Screen Size: 120 inch 16*9
Viewing Habits: 75% Sports 15% TV 10% Blue ray
Sources: Panny BD 85 and Comcast cable HD
Room: Light controlled Basement 12*17 room open to rest of basement
Throw Distance:17 feet
Seating: Primary 11 Ft. and 17Ft.
Budget: Under 500
Through research and budget constraints these are my two front runners Jamestown aka Shopping deals on Ebay 120 in. or Elite EZ frame my gut says Elite but my wallet says Jamestown your happy with the wall just any screen will blow you away. The Elite is roughly twice the price of the Jamestown and I wonder if I should just spend the extra now or get my feet wet cheap.
This has been a difficult decision so all advice and opinions are welcomed.
Thank you for any help and if any other info is needed please ask.
Scott
Budget: Under 500
Scott
