Fix screen vs Ceiling Recessed - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-12-2011, 07:18 AM - Thread Starter
Youg's Avatar
Hi everyone, I'm looking to invest in a projector and my room has an odd shape stopping me from putting a fix screen to the wall.
Is the quality the same between a fix and a recessed screen?
I'm looking to buy a Pana AE4000 with a 2:35 screen if possible. I'd like to do CHI with the lens memory fonction on the projector. (Light controled environment)
Since my room has an odd shape (don't want to invest in changing the room, it's a new house so I have other stuff to deal with), i'll like to put a recessed screen in it.
Any con's of using a recessed screen?
Thx a lot.
Youg is offline
post #2 of 4 Old 01-12-2011, 02:21 PM
schlitzie's Avatar
I did a motorized screen years ago -- while it is impressive when it drops down, the novelty wears off... And it is way more expensive and complicated to install as well. The biggest limitation is that if you ever want to change screen fabrics down the road (higher gain, etc.) you are not able to. Take my advice and go fixed frame if even remotely possible.
schlitzie is offline
post #3 of 4 Old 01-13-2011, 10:58 AM
programmergeek's Avatar
how about a fixed screen that drops down fromthe celing.
programmergeek is offline
post #4 of 4 Old 01-13-2011, 11:09 AM - Thread Starter
Youg's Avatar
Do you have any exemple of that? That would be good I think.
Youg is offline
Reply Screens
