New ranges of Monoprice screens seem to be coming soon - Page 16 - AVS Forum | Home Theater Discussions And Reviews
post #451 of 577 Old 04-14-2012, 09:30 AM
dougl99's Avatar
Originally Posted by dougl99 View Post
I purchased in late August and finally hung in late October. Had framers fir it in and then rocked and painted. I noticed wrinkles in the bottom corners, but since I still didn't have my room ready, no big deal. The remote stopped working in January when I was showing a buddy. No big deal, rooms not ready. Two weeks ago the whole thing quit working. The screen has only been down so I could show off about 10x. I verified voltage to the board. All good. Called Monoprice. 1hr and 51 minutes later.....must be defective, send it back. All I need is the board. Too bad, send it back. Trouble shooting from MP was non-existent. Only advice was to try another outlet (even though I told him I had voltage). 3rd rep said he would send out new screen and I could rob parts. I then rec'd an email w/ RMA#. I questioned this and haven't heard back. Hopefully they will send me a screen. I have carpet going in tomorrow and my onkyo receiver, ascend speakers, rhythmic sub and panny blu-ray are on the way. I cancelled the PJ for now and am ordering a Sharp 70" until this gets resolved. After a year of construction, very disappointing.
Monoprice sent me an entire new screen to rob the part I needed. Not the best way to go. 10 minutes, three phillips head screws and two modular plugs later I swapped the boards and was good to go. Any other situation and I probably would have been happy with a completely new product. Uninstalling this one would have been a large project compared to replacing a board. Kudos to MP for doing what they did under the circumstances. After a few weeks of me not returning the screen (they shipped it w/o requiring any payment) they sent a call tag from the freight company.
I have adjusted out some of the waves and while not completely satified with the outcome, it is very difficult to see while watching a movie...looks much worse with the lights on...and not worth uninstalling. Maybe move up my upgrade date.
This is a 133" motorized ceiling recessed screen using an Epson 3010.
dougl99 is offline
post #452 of 577 Old 04-16-2012, 09:04 AM
slybarman's Avatar
Did you try a hairdryer on the waves yet? Another member had success with that. I have meaning to try it on my multi-format, but have not found the time or energy to take the screen back down yet.
slybarman is offline
post #453 of 577 Old 04-16-2012, 09:07 PM
dougl99's Avatar
Haven't tried the hair dryer.
It seems if I could just add a small amount of weight to the ends of the bottom bar, the waves would go away. But easier said than done and probably not real attractive.
dougl99 is offline
post #454 of 577 Old 04-17-2012, 11:29 AM
SmokenAshes's Avatar
Liked: 53
When the screen is down try lifting the bottom bar up a little, like if your doing a curl up on the bar. Then let it back down, let me know if that worked.
SmokenAshes is offline
post #455 of 577 Old 04-17-2012, 10:14 PM
dougl99's Avatar
Tried it. No change.
Any idea if there is a way to "un"tighten the tension adjustment knobs. They only turn clockwise to tight the string. I was wanting to loosen it up and start over.
dougl99 is offline
post #456 of 577 Old 04-18-2012, 01:35 AM
Liked: 53
You should be able to turn it counter clockwise to loosen. That is thats how I do it with my Vapex tensioned screen.
post #457 of 577 Old 05-13-2012, 06:30 PM
str1der's Avatar
Quoted: 28 Post(s)
How does the Monoprice fixed screens compare to a DIY using BOC. What's the material like on the Monoprice screens?
str1der is offline
post #458 of 577 Old 05-16-2012, 01:52 PM
HaloArchive's Avatar
I would also like to know. Thanks!
HaloArchive is offline
post #459 of 577 Old 06-11-2012, 06:12 PM
sivart321's Avatar
Does anyone have a video of the masking system in action? Someone actually manually moving the masks in place and removing them?
sivart321 is offline
post #460 of 577 Old 06-28-2012, 06:56 AM
slybarman's Avatar
I'll see about making one for you.
Sent from my SPH-D700 using Tapatalk 2
post #461 of 577 Old 07-21-2012, 04:45 PM
curtishd's Avatar
Quoted: 152 Post(s)
I doubt it BUT does anyone know if any of the monoprice screens retain polarization? Simply put a cheap (Real D) pair of 3D glasses on your head and use another pair and shine your projector through one of the glasses lenses as if your eye is the projector. Now do you notice when you close one eye does the image get darker on the screen?
curtishd is online now
post #462 of 577 Old 07-22-2012, 01:47 PM
slybarman's Avatar
Took a while, but here is a video of the masking system in action:
post #463 of 577 Old 07-22-2012, 02:39 PM
sivart321's Avatar
Awesome. That was helpful. I have manual masks that I can put in place now, but this is a much more elegant solution and doesn't require me to store the velvet wrapped masks anywhere.
Thanks for taking the time to make a video!
post #464 of 577 Old 07-22-2012, 02:48 PM
slybarman's Avatar
You are welcome. Glad it helps.
post #465 of 577 Old 07-23-2012, 09:35 AM
curtishd's Avatar
Quoted: 152 Post(s)
Thanks for the video! Could you tell us how the screen is mounted to the frame? Snaps? Tension pocket with rod? or what?
post #466 of 577 Old 07-23-2012, 10:01 AM
slybarman's Avatar
A rod goes into a pocket along each edge of the screen material. Springs are then spaced all around holding each rod to the frame and tensioning the material - though not enough I think in my case.
post #467 of 577 Old 08-09-2012, 01:32 PM
mizzoutigers's Avatar
I take it by your comment that your screen has some wrinkles. Are you able to tension the screen more by shortening the springs? This screen really interests me due to the multi-format function. Thanks.
mizzoutigers is offline
post #468 of 577 Old 08-11-2012, 04:56 PM
slybarman's Avatar
I had considered buying some shorter springs, but never did. Another member posted that he was able to remove wrinkes from the screen with a hair dryer set on low to shrink the screen material slightly. I intend to try that approach this winter sometime.
post #469 of 577 Old 10-13-2012, 08:56 PM
JoeBoy73's Avatar
Quoted: 12 Post(s)
Liked: 26
Hello Everyone...just thought I would touch base with the owners of these screens to see what their long terms thoughts are. I'm looking for a screen and this seems to be a great value...I'm a "measure twice, cut once" kinda guy.
JoeBoy73 is offline
post #470 of 577 Old 10-14-2012, 08:08 PM
Shizzlenits's Avatar
Boy am I glad you bumped this thread. I just ordered the 106" multi-format in white.
I'm pumped!
Shizzlenits is offline
post #471 of 577 Old 10-14-2012, 10:33 PM
JoeBoy73's Avatar
Quoted: 12 Post(s)
Liked: 26
Awesome Shizzle....can't wait to hear you thoughts!
JoeBoy73 is offline
post #472 of 577 Old 10-15-2012, 08:59 PM
cr136124's Avatar
Quoted: 70 Post(s)
Liked: 695
I'm pumped!
Congrats! May I ask what projector are you going to use with this screen?
+1
Could you please share some pics as well?
cr136124 is offline
post #473 of 577 Old 10-19-2012, 12:51 PM
I'm pumped!
Pleeeeeeease post your impressions of this screen. This is the exact screen I am contemplating. I am especially curious how tight and smooth the screen material comes out since some have expressed issues with wrinkles. Thanks.
post #474 of 577 Old 10-19-2012, 01:12 PM
trgraphics's Avatar
I have the 106" with the grey screen. For this size, the screen pulls tight with no wrinkles on mine. I have replaced it with the SI 108" zero edge however. I loved the ability to change the aspect on this screen and wish I could convert the screen to the SI screen. Despite what they claim, it needs masking.
trgraphics is offline
post #475 of 577 Old 10-19-2012, 02:29 PM
cr136124's Avatar
Quoted: 70 Post(s)
Liked: 695
Could you please elaborate a bit more on "Despite what they claim, it needs masking."?
Thanks in advance!
cr136124 is offline
post #476 of 577 Old 10-19-2012, 02:33 PM
trgraphics's Avatar
I was refering to the SI screen. I can still see the greyish black bars on scope material and after getting used to the adjustable aspect of the monoprice, it's hard to get used to seeing those again.
post #477 of 577 Old 10-19-2012, 02:51 PM
cr136124's Avatar
Quoted: 70 Post(s)
Liked: 695
Oh, OK and thanks for your clarification.
I know that you already replaced the Monoprice screen, but I would like to hear your impressions on this screen. I'm planning on buying one in the near future and I really like the fact that you can use it in two different formats.
Looking forward to read your impression.
cr136124 is offline
post #478 of 577 Old 10-19-2012, 03:26 PM
trgraphics's Avatar
I was very pleased with the monoprice grey screen in 2d. I have a dual Benq W7000 setup and even with that for 3d the grey screen just wasn't bright enough for 3d. My setup is in my family room and I prefer not to watch movies or sports in total darkness. That's the only reason I went with the 1.4 gain SI screen.
The adjustable height aspect worked extremely well on my monoprice. Others have said they had problems, but I never did over the 6 months I used it.
If you don't have to deal with room lights, I would highly recommend the monoprice. The adjustable aspect makes a big difference while watching scope movies.
post #479 of 577 Old 10-21-2012, 03:03 AM
Skylinestar's Avatar
Quoted: 1044 Post(s)
Liked: 182
Is it true that smaller electric screen (such as 92") is impossible to get V pattern in the long run?
Skylinestar is online now
post #480 of 577 Old 10-23-2012, 09:55 AM
Thanks for the input trgraphics. I want to get the 106" mulitformat in white for my dedicated home theater (complete light control). I like the multi use of the white screen as opposed to the grey. Would your recommend the monoprice 106 in white for my primary use (movies in light controlled environment)?
Reply Screens
Monoprice , Projection Screens , Dalite
