New ranges of Monoprice screens seem to be coming soon - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 577 Old 10-21-2011, 02:10 AM
ockevin's Avatar
To those with the multi-format (masking) screens, does the pull latch centered on the masking bother you in any way? I know someone said it is undetectable in darkness, but it the photos it just sticks out to me, and I am wondering what your impressions are having lived with it for a while.
ockevin is offline
post #182 of 577 Old 10-21-2011, 07:38 AM
mbroder's Avatar
I don't notice it at when watching a blu ray movie at 2.35:1. I was was watching a letterbox movie on Netflix streaming the other day and realized it wasn't exactly 2.35:1. There was a little light spill onto the masking panels but they really do an amazing job of absorbing the light.
They absorb it so well, in fact, that when i hit the info button on my ps3 to see how much time was left in the blu ray I was watching, I couldn't see it ( info is outside of the letterbox bars).
mbroder is offline
post #183 of 577 Old 10-21-2011, 02:40 PM
ockevin's Avatar
Mbroder,
Thanks for responding. I am specifically wondering about the centered pull latch that is used to raise the mask. Compared to their regular fixed screen, it seems to stick out visually in the pictures, not sure if it 'disappears' when the room is dark. Does it ever bother you, does light spill light it up? Also, someone mention they could add a hook to adjust the height of the masks, to set at 2.4 for instance, is it possible? Final question, I believe the screen is attached on top and bottom by brackets and sits 2 inches off the wall. Is the bottom bracket needed, or could one just use a spacer on the bottom instead of attaching; I have some paneling on the lower part or the wall and prefer to not attach through it. Thanks for all your help.
ockevin is offline
post #184 of 577 Old 10-21-2011, 03:14 PM
mbroder's Avatar
Mbroder,
I guess if you are looking for it, you would notice it when there is light spill from a format that doesn't quite fit inside the masking. It doesn't bother me though. Like I posted above, 2.35:1 material fits within the masking so there is no light spill and I can't see the tab at all in a darkened room.
Yes, I think you can add some type of catch for other formats without too much trouble I would think.
With the bracket provided, I would definitely use the top and bottom brackets. If you wanted something stronger so you don't have to use the bottom, I think you can get some angle iron at home depot that would work well. If you get it, you'll figure it out
mbroder is offline
post #185 of 577 Old 10-21-2011, 03:32 PM
rakstr's Avatar
Quoted: 125 Post(s)
Liked: 64
Mbroder,
I would DEFINITELY use both brackets. There is also enough play with the thumb screws (which BTW secure the screen in place at the bottom) to give you a method to fix "plumb" should your wall be a bit "tilted". I was able to pull one side forward and the other push back to get the screen perfectly level and plumb on all 3 axis!
rakstr is offline
post #186 of 577 Old 10-21-2011, 03:39 PM
ockevin's Avatar
Thanks again Mbroder. Looking at the picture, the latch and the monoprice logo bother me. I worry about seeing them even without using the masks at 16:9, and the non-mask models look 'cleaner' without the latch. But your experience convinces me that those are not noticeable with lights out in true operation. Thanks for pushing me over the top, I am going for it.
ockevin is offline
post #187 of 577 Old 10-21-2011, 03:46 PM
rakstr's Avatar
Quoted: 125 Post(s)
Liked: 64
All is virtually invisible!
rakstr is offline
post #188 of 577 Old 10-21-2011, 04:12 PM
ockevin's Avatar
Rakstr,
About the brackets, I think I get it and I believe I have a solution to my situation. Also thanks for your input on the latch, it is stuck in my head, but I know once I have the lights out, I shouldn't have a problem.
ockevin is offline
post #189 of 577 Old 10-22-2011, 05:18 AM
slybarman's Avatar
. . . That's what she said? ;-)
slybarman is offline
post #190 of 577 Old 10-22-2011, 06:49 AM
rakstr's Avatar
Quoted: 125 Post(s)
Liked: 64
Rakstr,
If you decide to do something different for the bottom, use the intended bottom bracket on the top. You'll know why I say this when you see the parts. The top is a length of flat aluminum with a notch to "hang" the top of the screen, the bottom is angle aluminum to sit the screen ON. The reson for the long brackets is so you can get them secured to wall studs and allow you to position the screen left and right such that the mounts on the screen don't have to perfectly align. They are only a couple inches wide. IMHO, make sure you get this thing secured or your asking for problems.
rakstr is offline
post #191 of 577 Old 10-23-2011, 07:58 AM
Nathan_R's Avatar
For what it's worth, in my photos of the latch/logo, I had to crank up the contrast and brightness to insane levels in order to get them to show up at all in pictures. So mine are a terrible representation of reality.
PSN: KyFriedNate
Nathan_R is offline
post #192 of 577 Old 10-25-2011, 08:26 AM
JamesVG81's Avatar
Quoted: 56 Post(s)
Liked: 35
The 106 inch is on back order. Alot of people must be picking this up.
JamesVG81 is offline
post #193 of 577 Old 10-31-2011, 09:14 AM
Cholan's Avatar
Hi, pls check you pm.
thanks
Cholan is offline
post #194 of 577 Old 11-04-2011, 11:18 AM
ttusqrl's Avatar
Yeah, I'm waiting for it to come off too so I can order one. I'm tempted to grab the 120" but I think it will be too big for a 20' room
ttusqrl is offline
post #195 of 577 Old 11-04-2011, 11:20 AM - Thread Starter
fitbrit's Avatar
Quoted: 54 Post(s)
Liked: 50
No way. I have a 120" in a 16.5' room with the front row about 10' from the screen. Noone has EVER complained that the screen is too big.
fitbrit is offline
post #196 of 577 Old 11-04-2011, 01:05 PM
slybarman's Avatar
Well, just to give an opposing point of view:
I have 120" @ 14' seating and it is fine, but I would not want to be closer than that.
post #197 of 577 Old 11-07-2011, 05:46 AM
cstmstyle's Avatar
Quoted: 14 Post(s)
Could someone provide the overall dimensions in inches of the outside frame for the 106" and 120" screen. The site is not very clear to me if they are providing the screen measurements or the overall measurements.
Xbox Live- DragonsLee
"I'm not in this world to live up to your expectations and you're not in this world to live up to mine." - Bruce Lee
cstmstyle is offline
post #198 of 577 Old 11-07-2011, 06:50 AM
rakstr's Avatar
Quoted: 125 Post(s)
Liked: 64
Well you didn't clearly say which 106 or 120 inch screen but their website does provide information on the sizes of the viewing area and the border. I'm not home to measure my 106 variable format screen but the numbers below seem to be what I remember. Add the border to the viewing area and you should get the overall. Use their online chat, I've always had good luck with them.
Variable format 106" screen [1520x2546]
Viewing Area: 1320mm Height x 2346mm Width to 998mm Height x 2346mm Width
Border Dimensions: 100mm Top x 100mm Bottom x 100mm Left x 100mm Right
Total Screen Length: 2546mm
Fixed format 106" screen [1480x2506]
Border Dimensions: 80mm Top x 80mm Bottom x 80mm Left x 80mm Right
Total Screen Length: 2506mm
rakstr is offline
post #199 of 577 Old 11-07-2011, 08:29 AM
mbroder's Avatar
106 multi format is 101 1/2" x 64" to the outside edges
mbroder is offline
post #200 of 577 Old 11-07-2011, 09:04 AM
Droid6's Avatar
I ordered the 120" multi-format screen over the weekend and I should get it this week sometime. After I give it a few days to stretch I'll calibrate it with my Epson 8350 with my colorimeter and post my results here so those with a similar setup to me have some baseline settings to work with.
Droid6 is offline
post #201 of 577 Old 11-07-2011, 09:15 AM
JamesVG81's Avatar
Quoted: 56 Post(s)
Liked: 35
I think I'm going to have to wait till the 106 comes in stock. I belive the 120 will be to big for my 20x12 room. Sitting 10 feet back on the front row.
post #202 of 577 Old 11-07-2011, 10:21 AM
slybarman's Avatar
Did you get grey or white?
post #203 of 577 Old 11-07-2011, 10:48 AM
Droid6's Avatar
White.
Droid6 is offline
post #204 of 577 Old 11-07-2011, 12:18 PM
slybarman's Avatar
Thank you. What are your seating and throw distances? I am currently using an 8350 to throw 120" from 14.5 feet with seating at 14'. I am thinking of dropping to 106 when I get the multi format screen.
post #205 of 577 Old 11-07-2011, 01:26 PM
Droid6's Avatar
I sit anywhere from 9-16' away from the screen and my throw distance is 12'. If you're worried about not being bright enough I would definitely move the projector up a few feet rather than go smaller. The extra brightness you make up by going smaller can will be made by staying big and moving the projector closer.
Droid6 is offline
post #206 of 577 Old 11-07-2011, 02:08 PM
slybarman's Avatar
I had considered doing that, but I have it on a down pole (ceiling mount) and I was concerned that it would be distracting if I moved it forward of the seating.
post #207 of 577 Old 11-07-2011, 02:16 PM
Droid6's Avatar
How low is it? Mine is about 4' in front of me and I never pay attention to it.
Droid6 is offline
post #208 of 577 Old 11-07-2011, 02:29 PM
slybarman's Avatar
I remembered also after typing my last reply, that I had my previous projector professionally calibrated and at the time the guy figured out how many more lumens I would have ended up with by moving the projector ahead a couple of feet (from 14' to 12' I think it was) and we basically figured out it wasn't worth the effort.
I may still consider it though when I hang the new screen since I will be doing some work on the room anyway.
post #209 of 577 Old 11-07-2011, 09:38 PM
Droid6's Avatar
The calculator on Projector Central says there is a 5fL gain for 2 feet of distance. They calculate a 1fL gain buy leaving your projector at 14' and going down to a 106" screen. Now going 106" and moving your projector to 10.5' will net you a 13fL gain.
Just a little info to help your decision.
Droid6 is offline
post #210 of 577 Old 11-08-2011, 03:47 AM
slybarman's Avatar
Those are useful. Thank you.
kevings likes this.
Reply Screens
Monoprice , Projection Screens , Dalite
