Tab Tension Parts For Non-Tension Electric Screen ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-26-2011, 09:42 AM - Thread Starter
Blue Rain's Avatar
Quoted: 140 Post(s)
Liked: 40
Is there a way to make your own Tab Tension for an Electric
screen to keep the screen from curling ?
Can't be that hard.
The thing is I been searching the web for the parts or whatever
it is and can't seem to find anything.
Anyone have any ideas or where to look ?
PS: The price jump going from non tension to tension is Ridiculous..Has to be
a way to make your own on the cheap.
Polk 7.1
Samsung PN60F8500
73" 73738 Mits DLP
Onkyo TX-NR3008
Panasonic AE4000 Projector
Blue Rain is offline
post #2 of 5 Old 02-26-2011, 10:54 AM
Benito Joaquin's Avatar
Can't be that hard.
I've taken apart many screens and worked on fixing many tab tensioned screens and never really thought about it until now....it would be pretty easy to create your own tab tensioned system.
The problem is that there are too many unanswered questions to be able to do this safely. The scary part would have to be cutting the screen. Most non tab tensioned screens are cut straight down on the side. With tab tensioned, the cuts are bowed in towards the image -----> ) ( <-------
to make it work, that cut is necessary. tabs and the cord aren't too difficult, neither is attaching the cord to the tube.
I'll see if i can get my hands on a non tensioned screen and see if i can make it work. Seems like a fun project.
Benito
Benito Joaquin is offline
post #3 of 5 Old 02-26-2011, 12:51 PM - Thread Starter
Blue Rain's Avatar
Quoted: 140 Post(s)
Liked: 40
Benito
Hi Benito
Thanks for taking the time to reply..appreciate it !
I been searching the forum for last couple of hours on
DIY tension .
It seems the threads I did find it was the tension part that
was the most troublesome but this was for an entire DIY
screen not an already made electric non tension screen.
Yes after looking at some tension screens on youtube I noticed
that bow cut. This one isn't a bow cut (See Youtube Link ) and just
has the tabs with some kind of wire . There would be enough space on the sides of
non tension screen for tabs to be attached and still be abled to roll back up.
I was also thinking when attaching the tabs they could be staggered (Different Lengths )
to create that bow curve. Kind of like attaching the tabs in a C shape on the
right side and do a backwards C on the left side....Without the extreme curve of the
C of course
I'm just stuck on what type of wire is being used and how it's attached to the roll up rod....You have any idea ?
http://www.youtube.com/watch?v=bXKtiPaseII&NR=1
Polk 7.1
Samsung PN60F8500
73" 73738 Mits DLP
Onkyo TX-NR3008
post #4 of 5 Old 02-27-2011, 11:08 AM
Hi Benito
DIY tension .
C of course
The wire seems like the easiest part to me. Just a hint......it's not really wire by definition....more of a thick thread. Tabs, you can make yourself. It could get difficult to clean up after you hack at the screen. Giving it that finished look. Attaching the screen to the tube is also a breeze once you simplify things.
Benny
post #5 of 5 Old 05-05-2014, 10:07 PM
Cafe Latte's Avatar
I recently ordered a fiberglass backed Elite screen and the screen was rippled due to the bottom hanger bit not being correct and it was also damaged in transit. Anyway I was told I could keep the screen so I have a spare I can experiment on and I am wondering about making it into a tab tensioned screen. Any one done this yet and does anyone have any tips?
Regards
Chris
Cafe Latte is offline
Reply Screens
