3rd party RF+IR controllers ok with Da-lite? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-14-2011, 12:07 PM - Thread Starter
coolplazma's Avatar
I have a Da-lite Cosmopolitan Electrol Tensioned Cinema Vision (110"/16:9 model 94203) being shipped to arrive next week. I ordered it ($1650 shipped) with only the default 110v wall switch as their other control options seem way overpriced (> $250).
I am thinking of getting the Focupix dual remote kit (both IR and RF, plus trigger for < $100 seems like a great deal) and using it with the Da-lite screen. The Focupix kit appears to be fully compatible with the simple 4-wire AC power leads on the Da-lite.
Focupix product page: http://www.htdepot.com/Premium_Dual_...hv2pupd-wh.htm
Focupix install manual: http://www.htdepot.com/v/vspfiles/ma...switch-kit.pdf
Da-lite install manual: http://www.da-lite.com/products/install_pdfs/39.pdf
Any other suggestions or recommendations?
Coolplazma's HT Den project. Early project info. Needs update with final results.
coolplazma is offline
post #2 of 3 Old 04-21-2011, 12:05 PM - Thread Starter
coolplazma's Avatar
anybody?
post #3 of 3 Old 07-19-2012, 04:33 PM
davidlc's Avatar
Hey, did you try the Focupix?
I have the tensioned cosmopolitan elctrol110v wall switch as well. Da-lites control options are so expensive!
davidlc is offline
Reply Screens
