Does anyone have screen innovations Performance series??? - AVS Forum | Home Theater Discussions And Reviews
Old 07-16-2011, 08:21 AM - Thread Starter
Jaritta's Avatar
Hey guys, I am looking at getting the screen innovations Performance series. I was wondering if any of you have one or have seen them in action.
I havent seen them in action, but I am getting a screen sample from both them and Carada to compair.
Any help would be great.
Jaritta
Jaritta is offline
Old 09-11-2013, 06:47 PM
pacman9270's Avatar
Quoted: 84 Post(s)
Liked: 49
Wow! This is from a long time ago.
I own the tpf100lg model. I use a Sony vplhw30es projector at 11.5'. Great picture. Easy assembly.
Theater Setup: 5.2.5 (10.1 Auro3D) / ~3100 cu.ft. / Vaulted Ceiling
Projector:Sony VPL-HW30ES Screen:SI Performance Series 16:9 100" Source Player:Oppo BDP-103D Pre/Pro:Marantz AV8802A Amps:Emotiva XPA-5(Fronts/Surrounds) and BasX A500(Heights) Fronts/Surrounds:Sonus Faber Venere 2.0 Center:Sonus Faber Venere Center Front/Rear Heights:Definitive Technology PM1000 / ProCenter1000(VOG) Subwoofer:Dual SVS SB-2000 Speaker Wire:Monoprice CL2 12-AWG w/Bananas ICs:BlueJeanCables and Mediabridge
pacman9270 is offline
Old 12-23-2013, 02:15 PM
pacman9270's Avatar
Quoted: 84 Post(s)
Liked: 49
OK... Update...
This screen does not handle bright scenes very well. You can see the texture of the screen in the bright white spots. Can be very distracting. Thought I'd add this, in case anyone else was looking to purchase this screen.
Old 01-02-2014, 11:45 AM
programmergeek's Avatar
That doesn't really say much, the performance series is a great screen but refers to the frame I don't know what fabric you have pacman that your having issues with but any fabric with gain will have sparkles SI seems to be better than the most you can get a performance series with plain white and elimate all the sparkles you may want to address this with your dealer and see if he can just swap out the fabric that is pretty easy.
Jason
Note: Any posts are of my personal opinions and not to reflect upon any business.
Jason@programmergeek.com
908 578-6466
programmergeek is offline
Old 01-02-2014, 01:26 PM
pacman9270's Avatar
Quoted: 84 Post(s)
Liked: 49
I'm past my 90 days to return it. I didn't change the material. I am using what came in the kit. It is the Lunar 4K 0.85-gain screen material. Other than that, and price, I have no other issues. Looks great on the wall and all else looks great. If I ever change the screen, I'll probably try to build my own first.
Screen Innovations
