What are some good AT screens to get? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 07-28-2011, 11:29 AM - Thread Starter
blakxzep's Avatar
I'm basically a noob here and starting my own home theater in my basement and I was recommended I should get an AT screen and I explained everything in my thread about it so it'd be great if you guys could guide me in the right direction.
http://www.avsforum.com/avs-vb/showt...php?p=20651669
blakxzep is offline
post #2 of 7 Old 08-01-2011, 12:13 PM
Brad Horstkotte's Avatar
Liked: 68
There are two common types of Acoustically Transparent (AT) screens: perforated and woven.
Stewart is the perforated style I see used most often; they aren't cheap.
Woven, there are two companies that are used most often - SMX and Seymour A/V. SMX used to sell the material separately, but not anymore; Seymour still sells the material separately. A premade screen from either will run somewhere in the range of $1000-$2000. I wanted something cheaper, so I bought a frame from Jamestown Home Theaters, and the Seymour DIY AT material, and was able to come away with a big AT screen for several hundred less than I could have otherwise. Others build their own frames and add the AT material.
Brad Horstkotte is offline
post #3 of 7 Old 08-01-2011, 01:08 PM
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 942
You forgot Screen Excellence ............their En4k material is the best I've tested. SeymourAV is the distributor for dealer networks.............
doublewing11 is offline
post #4 of 7 Old 08-01-2011, 01:35 PM
schan1269's Avatar
I use the Screen Research Clearpix2 in Grey.
Easily the best screen there is. Be prepared for "checkbook shudder".
http://www.screenresearch.com/website/index.php
schan1269 is offline
post #5 of 7 Old 08-01-2011, 02:58 PM
Liked: 68
Right you are, for completeness I should have included that - based on the OP's linked build thread however, I surmised that might be a budget buster. I could be wrong though.
post #6 of 7 Old 06-07-2012, 09:30 PM - Thread Starter
blakxzep's Avatar
Yeah definitely, I don't want to kill myself on the checkbooks for sure. I mean some of those screens are option but looks like the best option might be to create my own, now is there a good tutorial on the forums that can guide me through the building process with the screen?
blakxzep is offline
post #7 of 7 Old 06-08-2012, 08:32 PM
Mike Garrett's Avatar
Quoted: 5616 Post(s)
Liked: 3599
Have you seen the EN4K material?
mjgarrett100@gmail.com
Mike Garrett is offline
Reply Screens
