Projector screen advice - 140" x 82", 16' throw, Epson 8700 UB - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 09-07-2011, 08:06 PM - Thread Starter
Drzy's Avatar
I was hoping I could get advice for a projector screen based on the room and specs below:
Projector: Epson 8700 UB
Throw: 16'
Image size: 140" wide by 82" tall
Room: Dedicated theatre room, light-controlled. See pics below.
Type: Prefer fixed screen
Diagram:
In a prior media room, I just got some no-name projector brand off eBay and it worked perfectly fine for my needs. But, that was a much more "normal" home theatre setup, whereas here I'm maxing out the capabilities of the Epson 8700. So, would I be shooting myself in the foot if I did that again? If so, what sort of screen should I be ordering?
The center in-wall speaker will be covered by the screen -- is that an issue for sound quality? I'm not sure how well sound passes through the screen fabric.
Any advice would be HUGELY appreciated -- I'm pretty desperate to get the screen ordered so I can start enjoying the room.
Drzy is offline
post #2 of 7 Old 09-08-2011, 08:35 PM - Thread Starter
Drzy's Avatar
Bumpity - very much craving advice and would love to hear anything you can tell me.
Drzy is offline
post #3 of 7 Old 09-10-2011, 12:58 PM - Thread Starter
Drzy's Avatar
Bump again -- somebody save me, please!
Also, first post edited to reflect a question I hadn't put in yet (the screen will cover the center speaker).
Drzy is offline
post #4 of 7 Old 09-11-2011, 10:54 PM
Davecraze's Avatar
Quoted: 158 Post(s)
Liked: 55
You will need an acoustically transparent screen to have the center channel behind the screen fabric. If you are getting an AT screen, I would go ahead and all the front three speakers behind the screen for a more cinematic experience.
Davecraze is online now
post #5 of 7 Old 09-25-2011, 06:25 PM - Thread Starter
Drzy's Avatar
Thank you Dave.
Can anyone tell me how I go about buying a screen of this size? I've been scouring the internet and can't find anything. Are there companies that sponsor/support this board that I can go to?
I'm really pretty desperate for help. Should I update the first post with more information about what I need?
Drzy is offline
post #6 of 7 Old 09-26-2011, 07:16 AM
mjg100's Avatar
Originally Posted by Drzy View Post
Thank you Dave.
For your projector to work with an AT screen that is 140" wide, you are going to have to go with a microperf screen with some gain. I would not look at anything with less than 1.5 gain. This size and type of screen will cost much more than your projector. Personally, I would look at a smaller screen for that projector. If you would like some more advice, please email me.
mjg100 is offline
post #7 of 7 Old 09-26-2011, 08:14 AM
Benito Joaquin's Avatar
just like mjg said. The size seems a bit big for the projector. You will definitely be stretching it's limits. We carry different manufacturers that can attack different budget points. Feel free to contact us for pricing.
Benito
Benito Joaquin is offline
Reply Screens
