High gain VS High contrast - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 12-03-2011, 10:04 AM - Thread Starter
domingos38's Avatar
Quoted: 22 Post(s)
Liked: 37
please explain the diference
and can u point me to a good High contrast screen in the $600 and lower range 120" screen
domingos38 is offline
post #2 of 7 Old 12-03-2011, 10:14 AM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
Hi gain refers to the amount of light reflected off the surface of the screen as measured with instrumentation. A standard gain is know as a gain of 1 or 1.1.
A high gain is anything over 1.3.
There are several technologies with providing gain. Angular reflective and retro reflective. Both have advantages and drawbacks.
High contrast are typically screens of a color other then bright white. The darker shade helps expand the contrast ratio between the darkest darks and lightest lights
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
post #3 of 7 Old 12-03-2011, 10:40 AM - Thread Starter
domingos38's Avatar
Quoted: 22 Post(s)
Liked: 37
so can i get an high contrast screen with diferent gains?
i keep reading that high contrast screens are better for low contrast ratio projectors yet i have seen it recommended for epson 8350's and 8700's .why?
post #4 of 7 Old 12-03-2011, 11:26 AM
selahsean's Avatar
From what I have read people are choosing a high contrast screen for better black levels. Some people find this has a negative effect on whites causing them to look dirty. If you are really worried about it you can have different vendors send you samples of their screen material to test.
selahsean is offline
post #5 of 7 Old 12-08-2011, 08:50 AM
bud16415's Avatar
Quoted: 784 Post(s)
Liked: 277
Don't confuse the CR a projector can produce with the CR a viewing room will allow. Darker screens with gain are designed around not widening or increasing the CR a projector can produce but rather preserving more of it when there is some form of ambient light. That light could come from outside the system or could be projected light bouncing around the room and returning to the screen to dilute the image. The light from one candle can diminish a 10,000:1 CR down to 1,000 to one.
There is also the issue of perception of contrast something that happens in our eyes as they dilate to an overall brighter image. Read up on absolute CR and ANSI CR.
Bud
bud16415 is offline
post #6 of 7 Old 12-08-2011, 09:24 AM
Tryg's Avatar
Lots of confusing and false information above.
1. High Gain means more light is reflected back in a certain direction.
2. High Contrast means a darker screen. This is just a marketing term because the screen cannot change the on/off contrast ratio of the image. Darker blacks? yes, but only because it is reflecting less light by being darker. Whites also suffer from less reflected light in the same ratio.
Tryg is offline
post #7 of 7 Old 12-08-2011, 12:25 PM
bud16415's Avatar
Quoted: 784 Post(s)
Liked: 277
A high contrast screen is virtually doing the exact same thing as a ND (neutral density) filter placed over the projector lens or in the case of photography a camera lens. An ND-2 filter is commonly used with projectors to attenuate the projectors output by 50%. In the case of a ND-2 screen it will also attenuate 50% of the light reflecting from the screen. No one questions using a ND filter in photography as weakening the cameras ability to reproduce white in a photo they just know that it changes the exposure iris by one click. Putting one on a projector doesn't change the spectrum of light making whites gray in any way. It only is limiting the intensity of the total light output. The same is true with doing such at the screen. The only difference is at the screen the ND surface is also acting on all stray light striking the screen attenuating it at the same ratio. Of course the drawback is if you have two screens of the same rate of dispersion one being a 1.0 reference white and the other acting as a ND-2 to get the same brightness of image output the later projector would have to be outputting twice the lumens. The reward being the screen could tolerate more light coming from the room.
That's the effect neglecting the idea of perception of contrast. In a brighter environment our eyes iris reduce allowing the brain to see the best CR possible and the screen shade becomes reference black and the contrast extends to the brightest area being reference white. This is easy to test at home by watching the credits at the end of a movie white letters on a field of black. Examine the black closest to the white and the black at the edge of the screen they are both the same black but the closer to the white you get the better the black. This is also the same black you have been watching during the movie but in the movie the image was overall much brighter increasing the perceived black.
Most high contrast screens don't stop at just being darker and attenuating light though they then add in elements of directional gain that focus more light to the center seat and less to the far side seating. This gain can bring back some of the lost brightness along with rejecting ambient light coming from the sides. Directional gain is not without issues though. Those being, it starts to exaggerate any tendencies to warm or hot spot the center of the screen. The high contrast screens are carefully designed to take things as far as they can in improving the screens ability to work in less than perfect conditions and having an outcome that given all the variables is a net win.
Below is a photo of an experiment I did with a homemade screen that was as black as coal. The lumens were increased by using a bright projector and a very small screen. The objective of the test was to show white along with black and all colors could be projected off a very black screen. This photo was taken with an ambient light level brighter than most office settings.
Bud
bud16415 is offline
Reply Screens
