what brand & model of 1.3 and 1.5 gain screen? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 12-29-2011, 04:29 AM - Thread Starter
audionewer's Avatar
can you give me any suggestion what 1.3, 1.5 gain projector screen i shall buy?
100inches screen with hd33 or acer h9500bd?
audionewer is offline
post #2 of 7 Old 12-29-2011, 12:19 PM
What kind of budget do you have in mind?
Some 1.3 and 1.5 gain screens are better than others.
Benito
AV Science sales 1 is offline
post #3 of 7 Old 12-29-2011, 02:14 PM - Thread Starter
audionewer's Avatar
max $200 dollars and it has to be 100inches and pull down
post #4 of 7 Old 12-29-2011, 03:04 PM
airscapes's Avatar
Quoted: 354 Post(s)
Liked: 286
Just do a Google, at that price point one is the same as the next.. china cheap, might go up and down once or twice.. good luck
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
post #5 of 7 Old 12-29-2011, 03:27 PM
as airscapes mentions....at that price point, you will more than likely be dealing with the same inexpensive material regardless of what manufacturer you purchase from. I'd suggest you up your budget a bit and consider a da lite screen. They can get you into a 100" pull down with good material for just a bit more.
Benito
post #6 of 7 Old 12-29-2011, 07:03 PM
KBMAN's Avatar
Quoted: 255 Post(s)
Liked: 140
OP,
just an FYI, but a 'middle of the road', meaning not cheap, but not 2K dollars will get you into the $600-$800 bracket. Da-lite and Carada come to mind. I spent just over 7 hundred on a 115" 'precision' brilliant white screen with a gain of 1.4. I think Da-lite will cost you a little more for the same screen. GET SOME SAMPLES!!!
KBMAN is offline
post #7 of 7 Old 12-30-2011, 12:01 AM
Smackrabbit's Avatar
Quoted: 31 Post(s)
Liked: 92
Originally Posted by KBMAN View Post
OP,
He is after a pull down screen which I don't believe Carada makes.
Chris Heinonen
Writer, The Wirecutter
Founder/Editor, ReferenceHomeTheater.com
ISF Level II Certified Calibrator
Previously: Senior Editor, Secrets of Home Theater and High Fidelity, Displays Editor, AnandTech.com, Contributor, HDGuru.com and Electronic House
Smackrabbit is offline
Reply Screens
