Suggestions needed: Ceiling mounted large screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 01-15-2012, 12:22 AM - Thread Starter
flyhigh123's Avatar
I'm looking for some suggestions on a ceiling mounted, motorized, tab tensionsed large screen.
Prefer 16:9, something 12-15+" feet across (not diagonal).
I've seen the ones on monoprice but feel that the 150 inch is a little small. I would like something even bigger but cost efficient.
Any suggestions and places to buy?
flyhigh123 is offline
post #2 of 11 Old 01-15-2012, 05:37 AM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 285
Will your projector actually light something that large correctly? Typically you need to spend upwards of $10,000+ for a HT projector with enough light to Illuminate a screen of that size correctly, even if you bought a high gain screen. So I would have to assuming this is for a business application, not HT.
Most large rooms in conference centers I have been in have Dalite screen, but I must say, I did some some wrinkles in the lower corners of the screens and they were tab tensioned..maybe just need to be adjusted..
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #3 of 11 Old 01-15-2012, 05:23 PM - Thread Starter
flyhigh123's Avatar
Good point. This is for ht. I was planning to spend less then 3k on a 3d capable projector for the screen. I think I'll go with the 150 inch from monoprice.
Any projector suggestions? Prefer LCD as dlp sometimes give me rainbow effect.
post #4 of 11 Old 01-15-2012, 07:44 PM
Mike Garrett's Avatar
Quoted: 5569 Post(s)
Liked: 3550
There isn't an under 10k projector (that I know of) that can light up a 150" 1.0 gain screen in 3D.
mjgarrett100@gmail.com
Mike Garrett is offline
post #5 of 11 Old 01-16-2012, 12:36 AM - Thread Starter
flyhigh123's Avatar
How about the new epson projectors?
How many lumens am I looking for if there is slight ambient light?
post #6 of 11 Old 01-16-2012, 05:15 AM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 285
You need to stop and do some research.. this is not like buying a TV.. And by research I really mean reading.. there is way to many variables to answer open ended questions like these..
Doug
post #7 of 11 Old 01-16-2012, 12:51 PM - Thread Starter
flyhigh123's Avatar
i have been reading, but the issue is that there is way too much information that doesnt answer a specific question.
For example, some people like 20 or some like 40. There is no way for me to easily know which projectors are ok for a screen of this size.
By me asking questions, it allows those with knowledge to give some advice. Why reinvent the wheel?
If others ask a question, and I have been down a similar path, then i can chime in.
I ask a question, projector and screen.
If someone has something similar, they can say, " i;m using X and X"
post #8 of 11 Old 01-18-2012, 06:17 PM
Liked: 3550
The Epson 5010 will give you around 7 or 8 Foot Lamberts with a new lamp on a 150" diagonal (1.78) 1.0 gain screen and this is if you mount it at it's shortest throw. Like I said 3D and large 1.0 gain screens do not work at this price point.
post #9 of 11 Old 01-18-2012, 10:19 PM - Thread Starter
flyhigh123's Avatar
Thanks AV science, i will read up on lamberts to see what a good number of lamberts should be.
I will also look into a 1.5 gain screen as well.
What projectors are there that can put out more light? I may need to wait another year for some of those higher end units to come down in price.
post #10 of 11 Old 01-18-2012, 10:25 PM - Thread Starter
flyhigh123's Avatar
based on this site:
http://www.projectorcentral.com/Epso...ulator-pro.htm
it seems like it can work? Am I reading it wrong? it shows 14FL at 1.0gain and 21 at 1.5gain?
post #11 of 11 Old 01-18-2012, 10:30 PM - Thread Starter
flyhigh123's Avatar
what are some companies that make a ceiling recessed 1.5+ gain screen?
I've seen da-lite and Elite. Any others?
Reply Screens
