Welcome to my Nightmare :) - AVS Forum | Home Theater Discussions And Reviews
Old 01-24-2012, 01:04 PM - Thread Starter
ozer19's Avatar
Hello all,
This is my living room. 13 x 22
I am getting an Epson 5010 projector (as you see I need all the lumens I can get) and I am looking for a screen that can handle this much ambient light.
My walls and floors are white.
The sliding door panel you see on the left.... I have 4 of those
Obviously I will get some kind of blackout curtain of some sorts to cover the glass sliding doors during for "during the day watching" (any recommendations on this also welcome).
My questions would be, what kind of screen would you recommend?
I am looking into Dalite 2.6 gain HP screen because my viewing angle is very narrow and I have lots of ambient light.
Should I go something with even higher gain?
I appreciate your inputs in advance
ozer19 is offline
Old 01-24-2012, 02:08 PM
KBMAN's Avatar
Quoted: 255 Post(s)
Liked: 139
you might have to spend some change and get the black diamond 2.4 g3 screen for that room....
KBMAN is offline
Old 01-25-2012, 07:05 PM
mbrennem's Avatar
Wow that floor is almost like a mirror, that IS a nightmare room for a projector!
mbrennem is offline
Old 01-26-2012, 10:24 AM
talkingparrots's Avatar
Does the high gain black diamond have similar properties to the lower gain black diamond in terms of performance for Black levels?
talkingparrots is offline
Old 01-26-2012, 01:24 PM - Thread Starter
ozer19's Avatar
I am looking into the Black Diamond and boy they are gorgeous!! Especially the no edge one. But wow, some pocket change!!!
ozer19 is offline
Old 01-26-2012, 08:40 PM
FunHouse Austin's Avatar
Gotta Pay to Play!
If you want to know if a product is "good", please tell us your definition of "bad" for an understood point of reference. Do you want subjective opinions or objective facts?
- FunHouse Media
FunHouse Austin is offline
Old 01-27-2012, 10:00 PM
bassage's Avatar
Quoted: 128 Post(s)
Liked: 29
Why not throw a dark rug on that floor?
bassage is offline
Old 01-28-2012, 10:39 AM
R Harkness's Avatar
Quoted: 1931 Post(s)
Liked: 1634
If any set up ever mandated a Black Diamond screen, yours is it.
If you really care to maintain decent contrast and good image quality in such a room, I don't think you could do better than the Black Diamond screens, and it may be worth the expense (depending on your budget, of course).
The .8 gain version would definitely do best at preserving image contrast (vs their higher gain 1.4 version, which handles room reflections/ambient light less well).
If you do get the .8 gain version, be conscious of not getting too big a screen. Most good quality consumer projectors aren't too bright these days, and I wouldn't go beyond about 100" diagonal with a .8 BD screen, to maintain good image brightness.
FWIW...
R Harkness is online now
Old 01-28-2012, 11:13 AM
neonsky's Avatar
Heck maybe if you ask nicely they'll do yours as a demo house.
neonsky is offline
Old 01-28-2012, 03:35 PM
goobenet's Avatar
You're probably best to throw down an area rug in front there anyways, if you have any sound as well, that floor is going to make it sound...interesting.
goobenet is offline
Old 01-29-2012, 07:14 AM
Fabricator's Avatar
Quoted: 20 Post(s)
almost nuthin. that IS a mirror.
good luck with that. that room is going to light up like a spotlight.
chasing rattles ......Pro8100 & Da-Lite HP 2.8 Cult member
Fabricator is offline
Old 01-29-2012, 01:35 PM
programmergeek's Avatar
I would look at the BD 1.4 I have done many rooms like your with success. Unfortinally I wish I could recommend another screen but you are kind of stuck unless you get a projector with 8000 lumens or greater than you can get into the .8 gain grays which are quite nice to help absorbed some of the light.
Jason
Note: Any posts are of my personal opinions and not to reflect upon any business.
Jason@programmergeek.com
908 578-6466
programmergeek is offline
Old 01-29-2012, 09:55 PM
afviper's Avatar
In addition to a large dark rug make sure your blackout curtains are a dark color. If painting the walls is out of the question get some acoustic panels for the walls. That should improve your sound and the dark cloth will cut down the reflections a bit.
afviper is offline
Old 02-02-2012, 06:33 PM
Mike Garrett's Avatar
Quoted: 5568 Post(s)
Liked: 3549
Tough room, but a BD screen would work for you.
mjgarrett100@gmail.com
Mike Garrett is offline
Old 02-03-2012, 07:20 AM - Thread Starter
ozer19's Avatar
Thank you guys! It seems that the BD screen is somewhat needed to get "what I want to get" from this room. Now, I wonder how I can get sponsored by them
ozer19 is offline
