Looking For A New Monitor - AVS Forum | Home Theater Discussions And Reviews
Old 01-26-2012, 05:00 PM - Thread Starter
Hennessy1's Avatar
I am looking for a new monitor that has the following attributes
-A minimum resolution of 1920x1200
-HDCP compatible
-24in in size
-I was looking for the better IPS displays but that is not a set in stone thing if the tn panels are good.
-Up to 1K for a budget
Room is limited so either a monitor that can have a sound bar installed like a dell or hp or is able to adjust high enough to allow for small speakers.
The monitor will mainly be used for gaming. An occasional blu-ray movie from time to time.
I recently purchased a samsung S24A850DW and after opening it up and reviewing the image quality the light bleed wasn't somthing I was fond of. I took some pictures from a dark screen it does not seem as bad compared to other monitors in my house but would you guys be able to look and tell me what you think if I should return it and go for another model.
I read more reviews where they complained about the black light bleed on this particular monitor from this thread
http://hardforum.com/showthread.php?t=1637404
Would the ips panels be less of a problem with black light bleeding then this type of panel?
Thank you for any help.
Hennessy1 is offline
