110-ish inch Screen - Carada or something else? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 02-13-2012, 05:57 AM - Thread Starter
yanathin's Avatar
I'm looking to buy a fixed screen for my home theater (using a 1080p JVC D-ILA projector) and I really don't know what I'm looking for. I honestly can't spend TOO much on it. My brother recommended looking into Carada screens and I noticed that a 110" costs $687. Is there any screen out there that's comparable but cheaper? How about Elite screens? I just need some direction - I know nothing about the projection screen market. Thanks!
yanathin is offline
post #2 of 7 Old 02-13-2012, 08:46 PM
blee0120's Avatar
Quoted: 429 Post(s)
Liked: 227
For that price, I think Carada will be very good. If you want to get a cheaper screen, I think you should go with a Visual Apex screen. I have had a visual apex and elite and I think visual apex are better quality and cost about the same. It should be half the price of the Carada. If you can work it in, I say get a Carada Brilliant White
blee0120 is offline
post #3 of 7 Old 02-18-2012, 07:10 AM - Thread Starter
yanathin's Avatar
Thanks for the input! It's a tough decision to make since I'm on a budget. My brother has a Carada and it looks fantastic with his JVC projector, but I don't know if I can swing it... Will there really be any noticeable loss of quality with a Visual Apex screen? What makes them better than Elite screens? And does brilliant white really make that big of a difference?
yanathin is offline
post #4 of 7 Old 02-18-2012, 10:15 AM
KBMAN's Avatar
Quoted: 255 Post(s)
Liked: 139
well, as a reference, I compared screen samples of the BW carada and the cinewhite of the Elite. NO COMPARISON....the brilliant white smokes the cinewhite that Elite has to offer. The elite seemed to be considerably dimmer with a blue push. The Carada seems to maintain and enhance brightness with little to no color shift. Also, the carada is a non-coated pvc material, so the viewing angle is very wide=very good.....
KBMAN is offline
post #5 of 7 Old 02-18-2012, 09:03 PM
blee0120's Avatar
Quoted: 429 Post(s)
Liked: 227
I liked the Visual Apex screen better and it was cheaper. But if you can get an Elite screen for cheaper, you will be satisfied with it. Also, you should look at Jamestown screens, I hear they are affordable too
blee0120 is offline
post #6 of 7 Old 02-18-2012, 09:32 PM
mjg100's Avatar
Deleted.
mjg100 is offline
post #7 of 7 Old 02-19-2012, 12:34 PM
Mike Garrett's Avatar
Quoted: 5550 Post(s)
Liked: 3539
You have a few choices. Give us a call for recommendations.
mjgarrett100@gmail.com
Mike Garrett is online now
Reply Screens
