Carl's place screen material versus Da-lite question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-14-2012, 06:30 PM - Thread Starter
BlitzBasicMan's Avatar
I'm upgrading from my old Da-lite screen (matte white 1.0 gain) which works great with my Hc4000. I was thinking of getting some more of the same Da-lite screen material ($244.00) for my bigger screen, but i came across "Carl's place" screen material which is much cheaper. Under $100.00 for the same dimensions. Can anyone say if it peforms as good as the Da-lite i described above. I wouldn't mind saving some $, but not if it means sacrficing the screen performance i've been used too. Thanks.
BlitzBasicMan is offline
post #2 of 2 Old 12-16-2012, 03:17 PM
tgrahn's Avatar
Did you get any more information on comparison between these two screens? I'm in the same boat and not sure if I should spend the extra for Da-lite or not.
thanks in advance,
Terrance
tgrahn is offline
Reply Screens
