any body know why da lite changed formula? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-26-2012, 02:53 AM - Thread Starter
counterbond's Avatar
on the high power da lite screens? i have the high power high contrast 2.4 and its not match for image quality as far as compared to my high power 2.8
counterbond is offline
post #2 of 2 Old 03-26-2012, 05:30 AM
airscapes's Avatar
Quoted: 353 Post(s)
Liked: 285
For the MONEY!
I was also told that the new process would produce more consistent results. But if you actually look at the products next to each other and with a microscope, you will see the old version look far more difficult to manufacture than the new version. up side be it small, of the new version, is it reduces the off axis dip with more white paint/emulsifier and a mix of bead sizes. So off axis you dip to 1 rather than the old .7/.8. Red shift is a little less as well (lots less beads). I am speaking of the standard not the HCHP. The HPHC has the same surface but a different under lament color
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
Reply Screens
