16x9 & 2:53.1 screen question - AVS Forum | Home Theater Discussions And Reviews
Old 04-09-2012, 03:10 PM - Thread Starter
socal swagger's Avatar
Quoted: 53 Post(s)
Liked: 25
okay projector i have is an Epson 8350 and in the market for a screen 106/120 either or.
I was considering a jamestown or elite fixed.
I have been reading regarding the 2:35.1 and black bars so i need some help. If a buy a fixed screen and play a movie that is 2:35.1 the movie will be displayed below the black border and the width of the picture will bleed over the the left and right borders is this correct?
I was under the impression that 2:35.1 would just display the black bars under the frames border if this is so i can manage. I mite go electric if this is the case
does anyone have any pics of a 2:35.1 movie displayed on a 16x9 screen so i could get a visual of it.
socal swagger is offline
Old 04-09-2012, 04:05 PM
Hockeytown Fan's Avatar
You'll just get the black bars on top and bottom is all
Help a Family in need, Show Them We Care! Like it on Facebook and tweet it!
http://igg.me/p/171832?a=874546
Hockeytown Fan is offline
Old 04-09-2012, 04:58 PM
ADDUpstate's Avatar
2.35 movie on a 16:9 screen will have black bars projected on the screen above and below the movie material.
16:9 or HDTV content displayed on a 2.35 screen will need to be zoomed for height and will end up with black bars on the sides of the image but still on the screen.
2.35 material on a 2.35 screen will be zoomed for height and will project the same black bars, but they will be displayed on the frame edge and surrounding area.
ADDUpstate is offline
Old 04-09-2012, 07:04 PM
Mike Garrett's Avatar
Quoted: 5565 Post(s)
Liked: 3542
With an 8350 and a 2.35 screen you would have to manually zoom the projector when going back and forth between 16:9 and 2.35. This means you would physically need to be able to get to the lens shift and zoom ring on the projector. Kind of frustrating to do without power functions on the projector.
mjgarrett100@gmail.com
Mike Garrett is online now
Old 04-09-2012, 08:08 PM - Thread Starter
Quoted: 53 Post(s)
Liked: 25
Thanks 120 / 16x9 screen it is just needed a better understanding
Old 04-10-2012, 02:04 PM
Liked: 3542
No problem. Would hate to see someone buy a 2.35 thinking they could easily do CIH and then find out they made an expensive mistake.
