Is the size of the screen measured diagonally or horizontally? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-13-2012, 10:33 AM - Thread Starter
Vancomycin's Avatar
When I see the size of the screen as being 110" or 120" I am not sure if it is measured diagonally or horizontally?
Normally the size of the TV screen is measured diagonally. Is projector screen ALWAYS measured horizontally ?
Vancomycin is offline
post #2 of 5 Old 04-13-2012, 11:43 AM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
Diagonally and of course the Aspect ratio it important as well 4:3 SD 16:9 HD 2.35:1 scope.. etc
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
post #3 of 5 Old 04-13-2012, 12:39 PM
DigsMovies's Avatar
Quoted: 34 Post(s)
Liked: 57
Unfortunately it's inconsistent. I frequently see size expressed both ways.
Here are some good sizing/aspect ratio formulas courtesy of Da-Lite:
Good Screen Formulas
DigsMovies is offline
post #4 of 5 Old 04-14-2012, 07:04 PM - Thread Starter
Vancomycin's Avatar
So everytime we see the dimension of the screen we have to call the company directly to verify whether it is measured diagonally or horizontally?
post #5 of 5 Old 04-17-2012, 07:03 AM
Mike Garrett's Avatar
Quoted: 5548 Post(s)
Liked: 3538
Usually a 16:9 aspect ratio screen is listed diagonally. When sizes of scope screens are discussed, often times those are listed by width. To me it makes more sense to give the width of the screen and the aspect ratio. It is easier to get all of the dimensions if you have width or height and aspect ratio.
mjgarrett100@gmail.com
Mike Garrett is online now
Reply Screens
