Sony VPL-HW30 and Carada Screen, reccomendations/questions. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-13-2012, 09:49 PM - Thread Starter
Hrimnir's Avatar
Hey guys, doing some more research on the projector and screen. He is pretty ready to pull the trigger on the Sony HW30 over the JVC RS45 primarily due to the ability to game on the Sony while still getting excellent black levels in movies and such.
We're going to go with a 118" Carada screen, most likely the criterion series. What i was curious if you guys think we should stick with the classic cinema white, or go for one of the others like the high contrast grey or the brilliant white. I'm guessing the classic cinema white should be fine since its a pretty bright projector, but, you guys are the experts ;-).
Here is a pic of the room, its captured from a youtube video from the video tour of the house for the seller, so im sorry for the crap quality, but it at least gives you an idea. The screen in the picture is a 120" according to the previous owner.
The lighting is very controllable in the room, i wouldn't say 100% but 85-90%, and i plan to take care of that window with a covering that will eliminate any outside light from it. Throw distance from projector to screen should be around 16'.
Klipsch RF-62 L/R, RC-62 C, Energy C-100 SL/SR, HSU VTF-15H, Marantz SR7008.
"All speakers sound good when you're on a coke binge in the middle of an orgy." - Heebdawg16
Hrimnir is offline
post #2 of 5 Old 04-15-2012, 06:43 PM - Thread Starter
Hrimnir's Avatar
135 views and not one person has anything at all to input?
Hrimnir is offline
post #3 of 5 Old 04-15-2012, 07:38 PM
mmarki's Avatar
Quoted: 18 Post(s)
Liked: 26
I would go with either the Brilliant White or the CCW, Unless you are really worried about the black levels. I have a 106 inch BW with the Sony 95 and I love it. The actual gain of the BW has been measured closer to 1 instead of 1.4. I think you would be happy with the BW, I know I am. Hope this helps.
mmarki is offline
post #4 of 5 Old 04-15-2012, 08:49 PM - Thread Starter
Hrimnir's Avatar
Thank you. I read a review earlier today on a website from 2004 that the Cinema white seems to only reflect about 65% of light thrown at it and you can clearly see light passing through it, etc. So i was kind of worried about that. I also read that the brilliant white is a much thicker material so i was kinda leaning towards that.
I figured i probably wouldnt need the grey given the projector and all, but thats why i posted a pic of the room.
I really appreciate you giving me some info, i'll likely go with the brilliant white. Especially in hindsight i was worried about viewing angles but looking at that pic the screen is gonna take up most of that wall anyways so its not like anyone is gonna be way off angle
Hrimnir is offline
post #5 of 5 Old 04-16-2012, 07:39 PM
Mike Garrett's Avatar
Quoted: 5571 Post(s)
Liked: 3551
For a 118" screen go with the Brilliant White fabric. If we can help you, give us a shout. In that room viewing angle would not matter, even if you were looking at a High Power. Room is just too narrow for it to make much difference.
mjgarrett100@gmail.com
Mike Garrett is online now
Reply Screens
