Will I notice a difference? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-20-2012, 05:15 PM - Thread Starter
crakerhead's Avatar
Quoted: 13 Post(s)
Will it make a difference? I'm a person that doesn't like to go the cheap route if I'll notice a difference. I'm comparing the Da-Lite 94341, Elite Screens R110WH1 and VAPEX9106. The DaLite has a 2.4 Gain while the other two have a 1.1 Gain. It's about a $350 spread from the Visual Apex to the DaLite.
It will be a 5010 Projector, sitting about 18ft back in a Light Controlled Room. Everything from Video Games to 3D movies.
crakerhead is offline
post #2 of 3 Old 05-20-2012, 05:56 PM
ADDUpstate's Avatar
I'm sure you'd notice a *difference*. Whether or not it's a positive difference is up to you. Do you need a high-gain screen material? Why are you comparing the 1.1 gain to the 2.4 gain?
ADDUpstate is offline
post #3 of 3 Old 05-20-2012, 06:55 PM - Thread Starter
crakerhead's Avatar
Quoted: 13 Post(s)
really didn't mean to, just happened to read good things about those particular screens. i understand the 2.4 will be brighter. i guess that's what im also asking, will i notice a useful difference between 1.1 and 2.4. thanks
Reply Screens
