Need advice on what screen to buy - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-24-2012, 07:28 PM - Thread Starter
Bear7616's Avatar
I'm purchasing the Panasonic PT-AE7000U what screen should I go with and what gain. Im wanting a 16:9 screen at 120" looking to spend around 1400 thanks.
Bear7616 is offline
post #2 of 6 Old 05-25-2012, 02:22 AM
ADDUpstate's Avatar
Need more info. Primary usage? Throw distance. AT or not? Light controlled? Etc. Etc. Etc.
ADDUpstate is offline
post #3 of 6 Old 05-25-2012, 08:01 AM
Mike Garrett's Avatar
Quoted: 5616 Post(s)
Liked: 3599
In a light controlled room, I would look at 1.2 or 1.3 gain white screen. As poster said above, need more information regarding your room. Several choices in your budget. Shoot us an email if we can help you with selection.
mjgarrett100@gmail.com
Mike Garrett is online now
post #4 of 6 Old 05-25-2012, 09:58 AM - Thread Starter
Bear7616's Avatar
The room is a garage 20x20 the first row will be approximately 11'
Bear7616 is offline
post #5 of 6 Old 05-25-2012, 09:58 AM - Thread Starter
Bear7616's Avatar
Primary will be movie room and football and gaming but mostly movies.
Bear7616 is offline
post #6 of 6 Old 05-25-2012, 10:01 AM - Thread Starter
Bear7616's Avatar
I will have control lighting ceiling is 8'7".
Bear7616 is offline
Reply Screens
