Which comes first the screen or the projector? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-28-2012, 09:42 PM - Thread Starter
HomeTheaterGuy74's Avatar
Hi:
I am building a new home construction home theater...
Which do I pick out first - the screen I want or the projector?
It seems as though they go hand and hand, I am just not sure which is supposed to come first...
HomeTheaterGuy74 is offline
post #2 of 4 Old 05-29-2012, 04:50 AM
BobL's Avatar
Liked: 56
This is a more complicated question. Room factors also play a role on what screen would work best for your situation. As long as the projector/ screen combo will be bright enough pick the screen more on room conditions.
BobL is offline
post #3 of 4 Old 05-29-2012, 05:54 AM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
Right. Get the screen size you want, AT or not depending on speakers. Then pick a projector with enough light output to fill it, enough lens zoom and offset for placement, and maybe auto lens shift if you went with a 2.35:1 screen.
psgcdn is offline
post #4 of 4 Old 05-29-2012, 06:08 PM
Mike Garrett's Avatar
Quoted: 5613 Post(s)
Liked: 3594
Just be sure to look at projector prices for what would be needed to light up that size screen. Don't want someone running out and buying a 13' wide screen and wanting 3D and then finding out that they don't have enough budget to light it up. Screen, projector and room all have to work together to have a great system.
mjgarrett100@gmail.com
Mike Garrett is offline
Reply Screens
