Will viewing content on 16:10 Projector screen make a difference? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-14-2012, 05:10 AM - Thread Starter
stevedawg85's Avatar
Quoted: 31 Post(s)
So I'm looking at at:
135 inch 16:9 screen -$175
139 inch 16:10 screen - $190ish
How will 16:9 content look on the 16:10 screen? Does that mean I'll get black bars? And how about 2.35:1 content? I know I'll get bars, but will the image be slightly bigger on a 16:10 because of that extra space?
I'm mainly getting the screen for my movie watching, tv shows, and very slight gaming. It's just a few dollars difference AND I'll get a few inches more (that's what she said). Will I experience any adverse effects if I go w/ the 16:10?
stevedawg85 is offline
post #2 of 4 Old 06-14-2012, 09:32 AM
Selden Ball's Avatar
Quoted: 3503 Post(s)
Liked: 1770
If you have a standard FHD projector (1920x1080) Yes: either the top and/or the bottom of the screen won't be illuminated, or (if you zoom the image) the sides of the image will be cut off.
If you zoom the projected widescreen image to fill the screen to its edges, there will be larger areas at top and/or bottom which are not illuminated by the projector. Some people like to cover the non-illuminated screen areas with a dark non-reflective cloth, similar to what's done in commercial movie theaters. This usually works more easily with screens which have a 2.35:1 size ratio to start with.
Unless you have a 16:10 projector (i.e. one intended primarily for use with computers instead of home theater), parts of it won't be illuminated. If you watch much 4:3 ratio source material, you would be able to zoom them to get a slightly taller image, though.
I'd suggest saving your pennies and spending them on a quality Blu-ray movie wink.gif
Selden
Selden Ball is offline
post #3 of 4 Old 06-15-2012, 09:50 AM - Thread Starter
Quoted: 31 Post(s)
Wow, good info thanks! appreciate it.
Like you said, I'll save the $ instead! Just gotta buy my screen before July 1, damn Amazon starts charging tax to us Texas folk!
post #4 of 4 Old 06-15-2012, 08:24 PM
lespurgeon's Avatar
Quoted: 31 Post(s)
Liked: 52
As Seldon said, if you have a 16:9 projector, then you want a 16:9 screen. 16:10 would just be a bother in every case. We have 16:10 at work, but so are the projectors.
lespurgeon is offline
Reply Screens
