Need screen advise for ultra short throw projector tabletop set up - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-17-2012, 12:27 PM - Thread Starter
Stacey Adam's Avatar
I'm currently projecting a 120" image onto a blackout cloth screen from an infocus in146 (3d ready 2700 lumen projector) from only about 5ft. This projector uses a dome wide angle lens to produce its ultra short throw and is a table top set up just below eye level. I have total light control, but the walls and ceiling are white (renting). Get plenty of brightness for 2d, but was looking for some gain for 3d. This is more of a make shift movie room than a high end home theater and seating is at the center of the screen.
Checking what screen material would give the optimum gain as I'll be using it for 2d and 3d.
Stacey Adam is offline
post #2 of 3 Old 06-17-2012, 02:32 PM
Mike Garrett's Avatar
Quoted: 7073 Post(s)
Liked: 4779
If you want gain for a table top setup, then look at the Da-Lite High Power screen. In that type of setup, you would get lots of gain. If you have any questions, shoot us an email.
mjgarrett100@gmail.com
Mike Garrett is offline
post #3 of 3 Old 06-18-2012, 04:15 AM
airscapes's Avatar
Quoted: 391 Post(s)
Liked: 307
+1
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
Reply Screens
