Screen Placement - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-26-2012, 04:56 PM - Thread Starter
sschantz's Avatar
Hi All,
I am at the tail end of my Theater set up
Onkyo 609 - check!
Epson 8350 - check!
Carada 96 inch screen - check (kind of) I am trying to figure out the best placement......The wall is exactly 7 ft (84 inches)from floor to ceiling and the Screen is 51.3 inches. Leaves me 32 inches....
16 inches from bottom and 16 inches from top just doesn't seem right. Any advice on what would be a decent placement??
Thx in advance
Make it a Great Day,
Shawn
Epson 8350
Carada 96' Screen
Onkyo 609
Sony BDP350
Polk CS1 Center channel
Polk Monitor 60
(4) Yamaha Satellite
Yamaha and Sony Subs
sschantz is offline
post #2 of 6 Old 06-26-2012, 07:36 PM
ADDUpstate's Avatar
Depending on how high your seating is, I would start with your eyes at 25% up the screen from the bottom of the screen material, not including the frame.
ADDUpstate is offline
post #3 of 6 Old 06-27-2012, 07:44 AM - Thread Starter
sschantz's Avatar
Thank you. Seating is regular sectional, maybe 18-24 inches high. Doesnt recline.
Not quite sure what you mean by 25%
Shawn
Epson 8350
Carada 96' Screen
Onkyo 609
Sony BDP350
Polk Monitor 60
sschantz is offline
post #4 of 6 Old 06-27-2012, 09:51 AM
ADDUpstate's Avatar
I will assume you are referring to a 16:9 screen AR.
At 96" diagonal, your screen material height is 47".
25% of 47" = 11.75"
75% of 47" = 35.25"
Seated eye height standard is 44"
So mark on your wall 44" off the floor.
Measure up from that mark 35.25". That is the height of your screen material.
All you need to do is take into account the frame height and mounting configuration, and add that to the mark you have on the wall.
Clear?
post #5 of 6 Old 06-27-2012, 10:06 AM - Thread Starter
sschantz's Avatar
So are you saying the top of my screen material would be 79 inches from the floor?
44 + 35 = 79?
Shawn
Epson 8350
Carada 96' Screen
Onkyo 609
Sony BDP350
Polk Monitor 60
sschantz is offline
post #6 of 6 Old 06-27-2012, 10:40 AM
ADDUpstate's Avatar
Yes. That puts your eyes, (if they are actually at 44" when seated) 25% up the screen, which is a good starting point.
In practice, I would shoot the image from your projector on the blank wall, measure out so you have 96" diagonal, and move the image up and down to see what you like. You may find that you like something different from the 25% up the screen.
Reply Screens
Displays , Onkyo , Onkyo Tx Nr609 7 2 Channel Network Thx Certified A V Receiver , Epson Powerlite Home Cinema 8350
