Screen recommendation, please help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-08-2012, 08:48 AM - Thread Starter
mrevo2u's Avatar
Quoted: 54 Post(s)
Getting closer to finalizing my dedicated theater and cannot decide on which screen. Room is complete bat cave, throw around 17', projector mounted in hush box at ceiling level on rear wall (will need to shift image down a bit). Projector will be epson 6010 and I want about 150" 2.35:1 screen. Was thinking black diamond or DIY. I realize that's asking a lot from the 6010.
mrevo2u is offline
post #2 of 3 Old 07-08-2012, 12:15 PM
henrich3's Avatar
Quoted: 573 Post(s)
Liked: 495
If you are able to lower the hush box closer to eye level I'd recommend checking out the Da-Lite High Power 2.4 gain fabric. You'll get the gain you need for that size screen. It won't do you much good if your pj is mounted on the ceiling however.
I'm not sure if SI makes the Black Diamond in a 150" size. Regardless, if you have a bat cave you don't need to spend the extra money or deal with the BD downsides of hot-spotting or color-shifting to get it's ambient light rejection properties.
http://www.avsforum.com/t/773065/high-power-a-review-part-1/0_40
henrich3 is offline
post #3 of 3 Old 07-09-2012, 03:02 PM
Mike Garrett's Avatar
Quoted: 5686 Post(s)
Liked: 3640
What you are wanting to do is not going to work very well. First of all the zoom, shift and focus controls are manual. Not very practical to do zoom method, especially when the projector is in a hush box. Second problem is lighting up that size and gain screen using zoom method.
mjgarrett100@gmail.com
Mike Garrett is online now
Reply Screens
