Aligning Projector With Curved Screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-11-2012, 04:54 PM - Thread Starter
studlygoorite's Avatar
Quoted: 102 Post(s)
Liked: 42
I installed my 174" curved scope screen and even without my anamorphic lens my picture bows downward in the middle. My projector is ceiling mounted and I am thinking that maybe, for a curved screen, the projector should be aligned more straight on to the middle of the screen or at least it seems that this would help. Anyone had any experience with this?
John
Anthem AVM 60, Paradigm Sub 2, Paradigm S8s with C5, Anthem Statement M1 Amps, 174" Curved AT Scope Screen, Epson Pro Cinema LS10000 Laser 3D Projector, Samsung 4K Blu-ray Player, Oculus Rift VR, Xbox One, PS4, Clark Synthesis Transducer For Chair
studlygoorite is online now
post #2 of 3 Old 07-12-2012, 08:52 AM
Mike Garrett's Avatar
Quoted: 5584 Post(s)
Liked: 3565
You will get some downward bowing when projecting a 16:9 image onto a curved screen. Think about it. As the image travels farther from the projector, the image spreads out more. The projector lens is designed to provide a straight bottom edge on a flat screen. By using a curved screen you have reduced the distance from lens to corner of screen. This means the image can't spread out as much so it reduces the size of the image. That makes the ends of the image, at the bottom, rise. The curve of the screen is to help the image after it goes through the A-lens and a curved screen is not needed for all A-lens setups. Usually only those with a throw ratio under 2.0.
mjgarrett100@gmail.com
Mike Garrett is online now
post #3 of 3 Old 07-16-2012, 05:38 PM - Thread Starter
Quoted: 102 Post(s)
Liked: 42
I was not aware of this but it doesn't bother me that much. I have a short throw so the curved screen helps with my anamorphic lens. Thanks for the info. Mike.
Reply Screens
