CARADA or JKP INFFINITY SCREENS - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-15-2012, 12:52 PM - Thread Starter
TK-713's Avatar
Quoted: 18 Post(s)
I have the JKP INFFINITY 106" screen and love it looks great. I am thinking of upgrading if there is anything to actually upgrade to.
I know the JKP screen have a light GREY color and because I have a total dark room would it be better to just go with a plan white screen?
I believe the JKP screens are suppose to be better quality then the CADARA but who knows. There is so many screens out there to chose from.
I am using the JVC HD990 projector and I must say the picture and expecialy the black levels look great u dont even notice the black bars.
I am just wondering if I made the right choice when it comes to the screen.
TK-713 is offline
post #2 of 4 Old 07-15-2012, 02:42 PM
ADDUpstate's Avatar
I had the JKP 0.6 gain Affinity 106"
Unless you literally have money to burn, keep what you have.
JKP is one of the best screens out there for non-AT screens, and you'll only get about 20% of what you paid if you try and sell it to move to something else.
Trust me, I did it.
Unless you are going to change to something completely different, (e.g. drastically larger size, AT screen) which is what I did, I would stay with what you have.
ADDUpstate is offline
post #3 of 4 Old 07-15-2012, 04:16 PM - Thread Starter
TK-713's Avatar
Quoted: 18 Post(s)
I am not sure if mine is .6, cant remember when I bought it. Also what is the difference from the other gains? I just hope I got the right Gain. If I was to go with a THX PERF SCREEN what would u recomend?
TK-713 is offline
post #4 of 4 Old 07-17-2012, 08:17 AM
Mike Garrett's Avatar
Quoted: 6957 Post(s)
Liked: 4648
Would need to know what size, aspect ratio and throw distance available to even make a recommendation.
mjgarrett100@gmail.com
Mike Garrett is offline
Reply Screens
