Screen for Epson 6010 in dedicated theater room - no ambient light - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-23-2012, 08:45 AM - Thread Starter
point1's Avatar
Quoted: 102 Post(s)
Liked: 31
Need help!
Here is what I have currently... 110" Dalite Pull down HP (I think its 2.8 or 2.4 gain) Model C and Epson 6500UB. I have the projector hanging down the ceiling with extensions not quite at eye level but a 12 to 18 inches above my head. My throw is about 16.5' feet.
I want to upgrade to the Epson 6010 because I want better blacks/contrast and maybe, just maybe get into 3D.
I think the High power might be too much so I am thinking about changing my screen.. the question is to what?
I think a white screen with a gain of 1.0 +/- will be fine since I have total light control (light turns off and its complete darkness) My ceilings and walls are dark as well.
So here are my choices:
Elitescreen 110" sable frame - $260.00 on Amazon
Draper Onyx 110" - about $860 shipped
Dalite 110" cinema contour - about 1k shipped
or
pick up Stewart screen 110" firehawk G3 locally for about $1400.00
what would you guys recommend based on the information I have provided? I am tempted to go with Elitescreen simply because of the pricepoint.
thanks!
point1 is online now
post #2 of 4 Old 08-25-2012, 08:09 PM - Thread Starter
point1's Avatar
Quoted: 102 Post(s)
Liked: 31
over 50 views and no comments or advice? ??
post #3 of 4 Old 08-25-2012, 10:46 PM
henrich3's Avatar
Quoted: 585 Post(s)
Liked: 502
If the image is too bright with the HP either raise the projector to lower the effective gain or get an ND filter. When the lamp dims you'll then have the option to lower the pj or remove the filter to recover the gain.
henrich3 is online now
post #4 of 4 Old 09-01-2012, 05:32 PM
Sherardp's Avatar
Carada Criterion screen with BW material should look and perform very well.
Click the link to see pics of my home theater
http://s450.photobucket.com/albums/q...oom/?start=all
Sherardp is offline
Reply Screens
Projection Screens , Epson Powerlite Pro Cinema 6010 Projector , Projectors , Dalite , Lamp Powerlite Hc 6100 Hc6500ub , Elitescreens , Draper , Stewart , Stewart Firehawk G3
