Use screen from rear projection TV with a home theater projector - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-25-2012, 04:41 PM - Thread Starter
dangerusty's Avatar
I'm just trying to confirm that I can use the front of a rear projection TV as a screen for an actual home theater projector. I've tried searching all over, but there's no good terms to find an example of this usage.
dangerusty is offline
post #2 of 5 Old 08-26-2012, 05:25 AM
ccotenj's Avatar
Liked: 101
never seen it done...
i don't think it would work very well... but i've thought wrong before...
- chris
ccotenj is offline
post #3 of 5 Old 08-26-2012, 01:24 PM
noah katz's Avatar
Quoted: 1107 Post(s)
Liked: 387
It will work, but it will likely be blisteringly bright, unless it's one of the more uncommon lowish gain RP screens.
It could work pretty well with a pj that lets you throttle down the light and increase CR with an iris.
Noah
noah katz is online now
post #4 of 5 Old 08-27-2012, 01:35 PM
starley's Avatar
NO, this will not work like you think it might.
There are screens that are both Front/Rear, however if your screen is a rear projection screen only then it will not work like you might think.
If you do see the image it will most likely be 1/3 the brightness and quality of the same screen used as designed.
Rear projection TV screens are usually coupled with a lenticular behind it and because of that it will not work at all unless used with that as designed.
Have you tried it yet?
I have seen RP TV Screens replaced with acrylic projection screens which can be used for both front or rear but I don't think that is what you are trying to do.....curious to know what your experience is if you do try it though. Keep us posted with updates as this sounds interesting....
S
starley is offline
post #5 of 5 Old 08-27-2012, 05:14 PM
noah katz's Avatar
Liked: 387
My bad, I haven't thought about RP since I abandoned my project years ago.
Correct, it likely won't work because the Fresnel lens on the back of the screen is designed for a relatively narrow throw ratio range, which is likely about half of what your pj's is.
What screen size are we talking about?
There are very inexpensive low-gain RP screens available, which are essentially tinted flexible plastic, as well as affordable acrylic ones (still low gain; it's the Fresnel and lenticular lenses that make the high-gain ones so expensive).
Google Harkness Hall, and "rear projection screen".
Noah
Reply Screens
Projection Screens , Projectors , Displays
