Help with picking out a screen.. - AVS Forum | Home Theater Discussions And Reviews
Old 09-02-2012, 04:57 PM - Thread Starter
frankie2075's Avatar
Quoted: 453 Post(s)
Liked: 108
moving to a new house want a projector screen in my basement.. the max throw distance i can have is 15' and my seating is going to be around 13'.. what size screen do you recommend for me and brands dont want to spend more then $1000 on a screen but dont want to spend that much if i dont have too.. thanks if u need more info just ask
frankie2075 is offline
Old 09-03-2012, 09:37 AM
Mike Garrett's Avatar
Quoted: 5613 Post(s)
Liked: 3594
You have to look at the whole system. In other words, projector, room and screen. Do you have a projector in mind? If not what do you want to watch on your projector, movies, sports and or 3D? What is your budget for the projector? What is your room like, size and color? What are you doing for audio? Need to know this, so that room for the audio can be planed. For a 13' viewing distance I would look around 120" diagonal (16:9). I would be careful if going over 138" diagonal (16:9) at that viewing distance. If you would like to get more into this subject more, shoot us an email.
mjgarrett100@gmail.com
Mike Garrett is online now
Old 09-03-2012, 09:57 AM - Thread Starter
Quoted: 453 Post(s)
Liked: 108
going to be movies and yes i would like 3d.. been looking at panasonic ae7000 epson 5010 maybe jvc 30x or rs45. room is a light color
Old 09-03-2012, 05:02 PM
Liked: 3594
I like the Epson 5010 paired with a 118" Carada Brilliant White screen. If you wanted to go a little larger (133"), then I would look at the Screen Innovations Solar 4K fabric with its 1.3 gain.
Projectors , Projection Screens , Replacement Lamp For Pt Ae7000u , Epson 5010 Powerlite Home Cinema 3d Front Projector , Jvc Dla X30b 3d D Ila Projector , Jvc Dla Rs45 Home Theater Projector 1080p Hdmi
