Epson 8350 Screen Help - AVS Forum | Home Theater Discussions And Reviews
Old 09-02-2012, 10:28 PM - Thread Starter
OoEricRoO's Avatar
Hello all,
I am new to all of this and I desperately need some advice to a good screen for my home theater set-up. I have been doing some research and am now more confused than when I started. Here is my set-up so far...
Projector: Epson 8350
Projector Mounting: will mount on my back wall. Wall is about 16-17 feet back. Projector will be mounted about 6 ft up on the wall (we have a 9 ft. Ceiling height). Mounting angle will be no more than 20 deg off center.
Screen Wishes: want around 110" screen. Budget - around $250 if possible.
Room: living room with some ambient light (2 windows plus light from adjacent rooms - open floor plan). Walls are tan ceiling is white. Viewing angle is no more then 30 deg.
Primary projector use: Sporting events and movies. I am not a super picky person, but I want something that will give me fairly decent quality.
Any advice would be much appreciated. thanks!
OoEricRoO is offline
Old 09-05-2012, 11:48 PM - Thread Starter
OoEricRoO's Avatar
No suggestions? I think I've decided to go with a high contrast gray screen, around .8 gain or so. Hope this will be enough. Any suggestions for a good hc gray screen?
Old 09-06-2012, 03:31 AM - Thread Starter
OoEricRoO's Avatar
Screen needs to be manual pull-down (or electric if one fits into my budget)
Epson , Epson Powerlite Home Cinema 8350 , Projectors , Projection Screens , Wall Mount
