Screen size - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-14-2012, 07:29 AM - Thread Starter
raypjuarez's Avatar
So I'm finally ready to purchase equipment after so much helpful advice on other components in my ht setup. My last question is this. My ht room is roughly 14ft length by 10ft width. Sofa will be all way to the back against the wall. What size projector screen can I get away with without it being too big.
raypjuarez is offline
post #2 of 4 Old 09-14-2012, 08:21 AM
airscapes's Avatar
Quoted: 353 Post(s)
Liked: 285
just like everything else there are many variables to take into consideration. Start by reading the stick about seating distance and size. Then there are your mains.. how much room do you need on either side.. if you can not fit the size you want (taking seating distance into account) will building a false wall with acoustic transparent screen material be a better fit? or will seating distance be to close for AT and you will be able to see the weave.. What color are the walls? do you need gain? etc.. After reading the sticky and guessing at the largest size you think will work, it is always a good idea to get the projector first and experiment on the wall watching from the seating location. You do not have to mount the projector for this test, just put it on a table or chair..
Good luck~!
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
post #3 of 4 Old 09-14-2012, 08:30 AM - Thread Starter
raypjuarez's Avatar
Thank for your reply. I'm going to follow your advice. There are things like you stated that I haven't taken into acct. I think ky biggest concern is that I only have 7ft high ceilings and three floor speakers in the front. The acoustic screen might be the way to go.
post #4 of 4 Old 09-14-2012, 06:06 PM
Mike Garrett's Avatar
Quoted: 5612 Post(s)
Liked: 3593
To do an AT screen with a 14' deep room, you should consider in-wall speakers. if you would like some help figuring all of this out drop us an email.
mjgarrett100@gmail.com
Mike Garrett is online now
Reply Screens
