tell me what you think - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-08-2012, 05:04 PM - Thread Starter
bighifi's Avatar
Quoted: 33 Post(s)
I can get a great deal on a 100 inch Stewart firehawk from a dealer. But it has some wrinkles in it. I am hoping to be able an get them out. Should I take a chance or just pass. 5 benjamins seems pretty good, but if I have to get a new screen it may not be such a great deal.
If I agree with you then we will both be wrong
bighifi is offline
post #2 of 4 Old 10-09-2012, 08:47 AM
ADDUpstate's Avatar
ADDUpstate is offline
post #3 of 4 Old 10-09-2012, 09:44 AM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3261 Post(s)
Liked: 3220
Where are these wrinkles? If just at a corner, and very small, you may never see them.
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is offline
post #4 of 4 Old 10-10-2012, 03:34 PM
Murbella7's Avatar
Quoted: 37 Post(s)
Wrinkles can be caused by various problems, the two biggest to worry about are, miss-handling (pulling down aggressively, disastrous with an electric screen) and the usual suspect... the aluminium tube the material rolls onto is too small to carry the weight, hence it bows and you get a V shaped wrinkle pattern down the screen, usually starting from just above centre. If the wrinkles are down the edges, then the main mounting material has lost its tension. My suggestion, pass. Don't waste your money. You will hate it forever.
Murbella7 is offline
Reply Screens
