Stewart CIMA or SI Performance Series ??? - AVS Forum | Home Theater Discussions And Reviews
Old 10-12-2012, 02:07 PM - Thread Starter
lycos100's Avatar
HELP... need guidace... looking for a 120" - 123" fixed screen for dedicated theater room that has zero ambient light issues. 16:9 ratio
JVC RS-45 projector; throw distance very flexible.
Room 24' long, 10' ceilings.
2 rows of seating; 2nd row elevated
Budget would allow (I think) either a Stewart CIMA or SI Performance Series screen. (would consider Black Diamond of I could find anyone selling them for less than MSRP)
Does anyone have an opinion on this? Which would you chose? Which would be a better fit for a JVC RS-45? Build quality? Etc., etc.
Feedback would be VERY, VERY appreciated. Thanks!
lycos100 is offline
Old 10-13-2012, 02:28 AM
Joesyah's Avatar
Joesyah is offline
Old 10-13-2012, 04:03 PM
Mike Garrett's Avatar
Quoted: 5589 Post(s)
Liked: 3574
The Stewart Cima works for you, so does the SI Solar 4K or BD1.4 gain screen. I will drop you a PM.
mjgarrett100@gmail.com
Mike Garrett is online now
