Help with SI Performance Screen - AVS Forum | Home Theater Discussions And Reviews
Old 10-13-2012, 03:49 PM - Thread Starter
GB_KSU's Avatar
I purchased a 110" 16:9 SI Performance Series fixed frame screen. I might have made a newbie blunder and was wondering if any of you could provide some input on the best way to fix it. The problem I am having is that I have installed the frame and the top edge is true and level. However the left and right sides of the screen are not. Basically the top portion is screwed to the right. I was having issues getting the image to line up with the screen correctly so I adjusted the brakets because the top of the screen was off slightly.
I am using a chief ceiling mount so I have some flexibility as far as tilting the projector. Will I be able to get the image to line up with the frame or do I need to take the screen down and adjust the frame itself? If I need to adjust the frame can this be done with the screen material attached? If not what is the proper way of removing and storing the screen itself until the frame is adjusted?
GB_KSU is offline
