BD compared to Stewart - AVS Forum | Home Theater Discussions And Reviews
Old 10-23-2012, 06:08 AM - Thread Starter
vrajku's Avatar
We are planning to upgrade our 92" Stewart screen. Our projector is a JVC RS 50 & we are leaning towards either a Stewart reflection active 3D or the BD SI screen with a 1.4 gain. Which screen would be best with 3D . We do not have a light controlled room . The screen will be in our family room though at night we can get the room to be quite dark. Any help from those who have owned both these screens would be helpful since these screens are pretty expensive & we live in a small town & no way to see one of these displayed. Thanks
vrajku is offline
Old 10-23-2012, 07:30 AM
AVS Club Gold
Mike Garrett's Avatar
Quoted: 4348 Post(s)
Liked: 2634
With a 120" 16:9 screen shooting onto a 1.4 gain screen from 15' using the RS50, I would want a little more brightness, especially since you are not in a light controlled room.
mike@avscience.com
Sony, JVC, Epson, Denon, Marantz, Yamaha, Onkyo, Parasound, Triad, Atlantic Tech, M&K, RBH, SVS, Polk, Stewart, Seymour, Falcon, DNP, SI, Screen Excellence, Carada, MicroLite & more.
Mike Garrett is offline
Old 10-23-2012, 08:53 AM - Thread Starter
vrajku's Avatar
Which is then a brighter screen - Stewart or BD?
vrajku is offline
Old 10-23-2012, 04:21 PM
BobL's Avatar
Liked: 55
The Active 170 is brighter (1.7 gain) and you could also consider their 5D material which is 2.0 gain. Are you going with a larger screen? I seen mike say 120" but I didn't see that in your post. If you are not going larger it would only make sense to just get new material for your current screen.
BobL is offline
Old 10-23-2012, 04:48 PM - Thread Starter
vrajku's Avatar
We are going larger - 120" diagonal. The only reason we were even thinking of the SI is that the black bars for a scope movie ( I have heard) are minimal whereas they will be seen in other screens. Masking is very expensive for us. Any advice would be appreciated.
vrajku is offline
Old 10-24-2012, 07:34 AM
omalley34male's Avatar
This is my screen 4 years then the problem came .. so be avare of STEWART stewart.jpg 289k .jpg file
and the tabtension ..
IMG_0305.JPG 473k .JPG file IMG_0315.JPG 832k .JPG file
IMG_0314.JPG 644k .JPG file
ID:	64513   Click image for larger version
ID:	64514   Click image for larger version
ID:	64515   Click image for larger version
omalley34male is offline
Old 10-24-2012, 04:23 PM
BobL's Avatar
Liked: 55
Have you called Stewart? I have seen Stewarts a LOT older than that and still look great. Something is up with your screen.
BobL is offline
Old 10-24-2012, 07:16 PM - Thread Starter
vrajku's Avatar
I also still have a fire hawk tab tensioned screen from Stewart that is almost 10 yrs old . This is the one we are trying to upgrade. But our screen even today is flawless
vrajku is offline
Old 10-25-2012, 11:58 AM
AVS Club Gold
Liked: 2634
Keep in mind the largest BD electric screen currently available is 110" 16:9 aspect ratio, so it is not an option if wanting to go with a 120" screen.
mike@avscience.com
Old 10-29-2012, 08:32 AM
BlakeSI's Avatar
We do plan to bring out a 2:35 Black Diamond motorized up to 138" diagonal.
BlakeSI is offline
Old 10-30-2012, 06:20 PM
AVS Club Gold
Liked: 2634
Yes, I should have probably added that, SI has BD electric scope screens currently scheduled for Q1 of 2013.
mike@avscience.com
