Acoustically Transparent Screens, (AT), latest options? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 22 Old 10-26-2012, 02:29 PM - Thread Starter
gnolivos's Avatar
Quoted: 357 Post(s)
Liked: 273
Hello,
I am thinking of moving to a larger screen for my dedicated HT room, from 104" to something closer to 110"-120"
The problem is I am limited on the sides of the screen... currently I have tower speakers on the sides, and basically the walls are limiting my ability to go beyond my current setup. So I am thinking of buying an AT screen so I can go wider and place the speakers behind.
I haven't researched for years this option, so wonder what there is today aside from the SMX line . I am on a reasonably tight budget. Would like to spend no more than $700 or so. is this possible? Also is moire an issue of the past?
Setup: Epson 5040 UB, 110" SilverTicket AT screen, PS3 bluray, Yamaha RX-V673 AVR, Polk and Athena speakers, Batcave room.
The Moderno Theatre! Slideshow (here!)
Pixar screenplay slideshows here!
gnolivos is offline
post #2 of 22 Old 10-26-2012, 03:05 PM
Jindrak's Avatar
Quoted: 51 Post(s)
Liked: 122
Definitely check our Seymour Screens. Good bang for your buck. SMX is def. expensive. Other options would be Carada or Stewart screens.
http://seymourav.com/screens.asp
http://www.carada.com/
http://www.stewartfilmscreen.com/
If one is going to make a simplistic assessment of the value of different alignments, it would be that sealed/IB goes the lowest, at the highest cost per dB; horns have the lowest cost per dB at the expense of size, and vented box characteristics lie in between the other two. None is inherently superior across the board, neither is any inherently inferior across the board. The one to use is the one that fits your response and output needs, available space and bank account. -BFM
Jindrak is offline
post #3 of 22 Old 10-26-2012, 04:14 PM
Elite Benito's Avatar
you can take a look at the A4K material. Just won the CEPro 2012 BEST Award-Projection screen.
Benito
Elite Benito is offline
post #4 of 22 Old 10-26-2012, 05:18 PM - Thread Starter
gnolivos's Avatar
Quoted: 357 Post(s)
Liked: 273
I see no AT screens there even close to $700. Am I missing something?
gnolivos is offline
post #5 of 22 Old 10-26-2012, 07:29 PM
Davecraze's Avatar
Quoted: 158 Post(s)
Liked: 55
A seymour av (the cheapest option mentioned) in the size you want will cost around 2x your stated budget of $700.
SMX is even more, Stewart is a lot more and Carada doesn't make AT screens.
4k (unnecessary unless you sit like only 8 feet from the screen) material will be over 700 just for the fabric.
If you are limited to 700 dollars, your only real option besides DIY is to have Jamestown Screens make you a screen and ask them to use seymour AT fabric. They will order it from seymour and cut it to size for your frame. You will need to assemble it but it is not hard - follow the instructions carefully, especially when stretching the fabric over the frame.
chriscmore and gnolivos like this.
Davecraze is offline
post #6 of 22 Old 10-26-2012, 08:33 PM - Thread Starter
gnolivos's Avatar
Quoted: 357 Post(s)
Liked: 273
My gosh, thanks.... those Jamestown Screens screens are so inexpensive!
gnolivos is offline
post #7 of 22 Old 10-26-2012, 08:56 PM - Thread Starter
gnolivos's Avatar
Quoted: 357 Post(s)
Liked: 273
Found this one within my budget...
ER120WH1-A1080P2 (google this, it is an Elite screen)
gnolivos is offline
post #8 of 22 Old 10-28-2012, 07:27 PM
Davecraze's Avatar
Quoted: 158 Post(s)
Liked: 55
I had read a few reviews on avs about Elite AT screens and some people complained of moire and streaks on the screen.
I think Elite has a new 1080p AT material that has a tighter weave so maybe that is no longer an issue.
post #9 of 22 Old 10-29-2012, 03:03 PM - Thread Starter
gnolivos's Avatar
Quoted: 357 Post(s)
Liked: 273
I see Elite has a new AT material as you say. However only available in 2.35:1 format.
gnolivos is offline
post #10 of 22 Old 10-30-2012, 10:35 AM
Depends on what type of unit you are looking for. On certain models, it is only available in 2.35 but if you are looking for a regular fixed frame, look into the Peregrine series. It is offered in 2.35 and also 16:9 in numerous sizes. You also have the option of purchasing A4K material only.
Benito
post #11 of 22 Old 10-30-2012, 11:50 AM
chriscmore's Avatar
Quoted: 122 Post(s)
Liked: 111
X2. If you want to stay on the <$700 budget but keep a reference quality image, then Jamestown is the way to go. Just this weekend I visited "nebrunner"'s incredible home theater in Omaha and it was textbook-perfect quality and performance, yet he kept within his budget by not only doing a lot of DIY but also using Jamestown for the screen frame. Jamestown makes a great product without sacrificing quality on what you'll be watching - the screen layer.
Cheers,
Chris
Seymour AV
515-268-3369
Seymour-Screen Excellence
515-450-5694
chriscmore is offline
post #12 of 22 Old 10-30-2012, 07:10 PM
Mike Garrett's Avatar
Quoted: 5548 Post(s)
Liked: 3538
Take a look at this post: http://www.avsforum.com/t/842769/the-official-seymourav-center-stage-screen-thread/1830#post_22540850
mjgarrett100@gmail.com
Mike Garrett is online now
post #13 of 22 Old 10-30-2012, 07:42 PM - Thread Starter
gnolivos's Avatar
Quoted: 357 Post(s)
Liked: 273
That post is for a Seymour XD screen, not Elite. Right?
gnolivos is offline
post #14 of 22 Old 10-30-2012, 10:13 PM
Davecraze's Avatar
Quoted: 158 Post(s)
Liked: 55
Correct that seymour av doesn't have a moire problem. I have a seymour AT fabric screen and no issues there. My post was regarding moire on an Elite screen.
post #15 of 22 Old 10-30-2012, 10:34 PM
Frosteh's Avatar
Either get some Seymour XD fabric and make a screen yourself or do what was suggested earlier and have Jamestown use the fabric and make you a screen. Either will probably come out similar in price.
Frosteh is offline
post #16 of 22 Old 10-31-2012, 05:24 AM - Thread Starter
gnolivos's Avatar
Quoted: 357 Post(s)
Liked: 273
I'm worried that more than a few people on that thread stated that they can see the XD weave pattern as far as 12 feet, some say even more. (on white portions of the screen). I'm kind of eagle eyed so I think I may be amongst those that notice and would be bothered by it.
gnolivos is offline
post #17 of 22 Old 11-01-2012, 12:08 PM
Glenn Baumann's Avatar
Quoted: 113 Post(s)
Liked: 54
Then you are definitely a candidate for a 4K screen... And the substantial increase in greenbacks required to join that club! wink.gif
Glenn Baumann is offline
post #18 of 22 Old 11-03-2012, 08:02 AM
Liked: 3538
Double post.
post #19 of 22 Old 11-03-2012, 08:05 AM
Liked: 3538
Sorry, grabbed the wrong post. Needed the one right above, what I linked to. Here it is: http://www.avsforum.com/t/842769/the-official-seymourav-center-stage-screen-thread/1830#post_22540813
post #20 of 22 Old 11-05-2012, 02:29 PM
zheka's Avatar
Quoted: 29 Post(s)
Liked: 26
that's pretty brutal. cannot wait for the "measurements and side-by-side screen shots".
zheka is offline
post #21 of 22 Old 01-16-2014, 02:01 AM
davidahn's Avatar
@Davecraze, thank you SO much for the pointer to Jamestown! I was going to have my cabinet guy make the frame and get the CenterStage XD material from SeymourAV, but he's overwhelmed with just the cabinets, and from their web site, sounds like Jamestown will give me a much better frame anyway. VERY reasonable price for a huge 156" 2.4:1 screen with a rectangular aluminum outer frame. I just paid the PayPal invoice, I'm told about 17 days lead time. I can't wait to see what this setup will look like with my VPL-VW600ES!!! 4K, here we come.
davidahn is offline
post #22 of 22 Old 12-14-2014, 11:45 AM
asoofi1's Avatar
Quoted: 933 Post(s)
Liked: 435
How did your Jamestown screen turn out? Since it has been almost a year, any issues with bowing or anything else?
asoofi1 is offline
Reply Screens
