Pull Down Screen - How To Flatten Wrinkles - AVS Forum | Home Theater Discussions And Reviews
Old 11-05-2012, 11:33 AM - Thread Starter
mantaraydesign's Avatar
Quoted: 119 Post(s)
Liked: 27
Hi,
Anyone know a way to take out all the wrinkles on the pull down screen?
I have a pull down screen but the bottom of the screen starting to show wrinkles. Can you take an iron and put it on warm but NOT hot and iron all the wrinkles out? I am talking about the iron you use to iron your clothes.
I am thinking there is not much you can do about it since it is a pull down screen.
Thanks for any advice!!
mantaraydesign is offline
Old 11-05-2012, 11:41 AM
airscapes's Avatar
Quoted: 315 Post(s)
Liked: 264
1. You can buy a new screen.
2. Or you can make a frame, cut the fabric from the roller and place on the frame.
3. The screen is vinyl, using an iron will guarantee you buy a new screen.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
Old 11-05-2012, 11:58 AM - Thread Starter
Quoted: 119 Post(s)
Liked: 27
I will give it a try.
