What's the best hardware to use to wall mount this screen? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-07-2012, 08:32 PM - Thread Starter
Prime316's Avatar
Quoted: 179 Post(s)
Liked: 204
I have a 92" fixed frame screen that has a keyhole bracket attached on each side. No mounting equipment came with it.
Projector: Benq W1070 1080p 2D/3D
AVR: Denon X2200W
Mains: Klipsch RF-62ii x 2
Center: Klipsch RC-62ii
Surrounds: Klipsch RS-42ii x 2
Subs: Dual Hsu VTF-15H's
Prime316 is offline
post #2 of 3 Old 11-08-2012, 07:03 AM - Thread Starter
Prime316's Avatar
Quoted: 179 Post(s)
Liked: 204
Anyone?
AVR: Denon X2200W
Prime316 is offline
post #3 of 3 Old 11-08-2012, 08:20 AM
ADDUpstate's Avatar
Most fixed frame screens these days use a Z-bar or French Cleat.
I would suggest you pick one or two up at your local home improvement retailer and see if you can make it work.
On one of my last screens, I didn't even need to attach the mated side of the z-bar to the frame. I just attached one to the wall, and there was a groove in the frame itself that worked perfectly. Otherwise attach the other side to the frame and you're all set.
GL
ADDUpstate is offline
Reply Screens
