Choosing Screen Material - AVS Forum
Old 11-09-2012, 06:36 AM - Thread Starter
brhaugen's Avatar
I just purchased my first projector... an Epson 705hd. I'm going to attempt to build my own screen. I've been looking online at different screen materials and am wondering if anybody has any experience with either of the following:
http://www.ebay.com/itm/140750634812?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
or
http://www.ebay.com/itm/330752601351?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
My screen will be approximately 110" with seating about 12'-13' away. My room is fairly well light controlled, however, the walls and ceiling are light colored. Does anybody have any thoughts on what would provide the better picture? Please feel free to suggest any other low-cost solutions if you have any. Thanks in advance for any advice you can give.
brhaugen is offline
Old 11-16-2012, 01:50 PM
umr
AVS Club Gold
umr's Avatar
Liked: 35
You need screen gain for that application. Look at a Stewart StudioTek 130 or a DaLite High Power or a DIY gain material.
umr is offline
Old 11-16-2012, 01:58 PM
airscapes's Avatar
Quoted: 94 Post(s)
Liked: 130
Paint the walls and ceiling a minimum of 5' from the screen a dark color. Visit the DIY screen sub forum for low cost DIY solutions.
airscapes is online now
Old 11-26-2012, 09:01 AM
Screen Saver's Avatar
Draper has a pretty good screen surface selection tool. It might help you figure out the qualities of the material you want. You've linked to two materials that are probably 1.0 gain at best (not sure about BOC).
http://www.draperinc.com/ProjectionScreens/SurfaceSelector.asp
Screen Saver is offline
