Advice on new screen-Help, TTY - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-23-2012, 07:47 PM - Thread Starter
spwerlin's Avatar
I am in line to get a new jvc 4810 and i need a screen. My room is completely light controlled, however as I intern at various places i can move a bit-so painting is out and i have white walls. one side is completely open the other has black curtains hanging to take care of most of that, and there are 12 foot ceilings in white. Budget wise, I would like to be around $1k, used or new. I see alot of Stewart and SI screens on ebay-just never take the plunge because i want to be sure of what i buy. Looking at a 92 inch screen at about 13 foot seating distance. I know a lot of people like the hp's by da-lite or should i go with a used si or stewart. suggestions?? ty for your time and help
spwerlin is offline
post #2 of 2 Old 11-26-2012, 07:31 AM
Mike Garrett's Avatar
Quoted: 7089 Post(s)
Liked: 4796
At 92" you do not need or want an HP screen. I would take a look at the Stewart Cima 0.92 gain screen. Nice gray fabric screen with a little higher gain than most of the gray screen in your price range. If us a call if you would like to discuss.
mjgarrett100@gmail.com
Mike Garrett is online now
Reply Screens
